Post your latest oil change
Coworkers 2010 Chrysler T&C 3.3 V6 157K miles
Out: Shell Rotella T4 15W40 Protec WIX PXL51515 2 months 2,000 miles.
In: same
Also replaced ball joints, front struts (non-quick struts) tie rods inner and outer, rear shocks and aligned the front end. I am glad I don't do that on the floor every day.
Did a few oil changes over the weekend.
2015 Cadillac XTS 93298 miles
Out: QSHM 5W30/ FE10575
In: QSHM 5W30/XG10575
2021 Chevy Spark 31688 miles
Out: PP 0W20/ PF64
In: Same
2005 Honda Accord Hybrid 167067 miles
Out: PPHM 0W20/ 57356XP
In: PPHM 5W20/ PH7317
2010 Ford Crown Victoria, A friend of my nephew's car.
Out: unknown oil but a motorcraft filter!
In: PP 5w30/ MC Filter
150,789 miles.
Also did intake manifold, transmission service with a new pan that has a drain plug, tune up and partial coolant change. His manifold was leaking bad definitely needed it!
I did the intake on my 99 right after I bought it. I went to change thermostat and the original all plastic intake cracked taking the thermostat bolts out. Not a bad job, but those rear crash bracket fasteners on the driver's side head were real fun to get to on the back side.
Ah yes, that crash bracket bolt is a bear! I ended up buying a 15 mm swiveling ratchet wrench that help out a lot but still difficult. This one went pretty smoothly until I dropped a washer in one of the openings on the aluminum crossover. Added two extra hours of work taking the manifold off fishing it out and putting it back together but thats how it goes sometimes 🤦
2010 Lexus GX460, 71k odo
Out: Supertech 0w20 SP, Wix Filter, 2925 miles severe duty 90% towing
In: Total Quartz 5w30 Long Life SN, Champ P968XL filter
I will be doing a wix UOA on the supertech. I'm out of wix filters, and will not hesitate to buy more if the price is right. I will be doing a wix VOA on the Total Quartz to see what Long Life means. I havent scoured the russian club forum to see if its already there, but its still fun to contrast even if it is.
So the MC3 has an oxidation value of ~12 whereas the Long Life has an oxidation of ~20.
Also the Long Life lacks Mg and has elevated B levels.
2021 chevrolet 2500hd 6.6l L8T
~3000 miles, changed due to low oil warning. dealer serviced prior to our purchase. truck has 55k miles on it.
out/off: 5.5ish quarts Dealer bulk 5w-30 & ACdelco PF63
in/on: 8 quarts Mobil 1 EP 5w-30 & Fram Titanium FS10575
Changed 2 cars this past weekend
05 es330 128k
Out : M1 High Mileage 5w30 with wix filter
In : Castrol Edge 5w30 with wix filter
Changed cabin and air filter too
Oci 5k
99 4runner 432k
Out : M1 High mileage 5w30 with wix filter
In : M1 High mileage 5w30 with wix filter
Also lube the driveline, it was much overdue
Oci around 5.5k
2015 Subaru Outback 2.5 (with Fumoto)
Out: @100K, PP 5W 30 with WIX (been using 5W 30 last few OCI instead of 0w 20 due to oil burning)
In: @105.5K "Minor" Franken Brew of PP 0w 20 (4.2 qt), Castrol 10W 30 (0.4), M1 0W 40 (0.5) with WIX - wanted to get rid of leftovers
