Post your latest oil change
After not being able to rustle up this thread and after posting in a related thread yesterday, I have found this thread here at least. Today, the search function worked fine. Weird that it didn't work yesterday. A glitch in the matrix, I suppose. Anyway, repost:
Miss Moneypenny got an oil and filter change at 63k miles yesterday.
Old Rotella jug for and red funnel for the old oil. An adjustable bungee strap to keep the coolant expansion tank out of the way. A 10 mm socket for the bolt that holds the expansion tank, an 8 mm Allen bit for the drain plug, a 27 mm socket for the oil filter housing. A 6" extension, two ratchets, and one breaker bar. Oil filter, o-ring, copper washer. The grey funnel is for the fresh oil. I'll ley you shiver with anxiety whether or not I used a torque wrench for the drain bolt and filter housing.
The tank has to be moved out of the way because the filter housing is in a slightly challenging position if you have adult-size hands. The oil filter housing is somewhat visible behind the coolant hose. Look inside the red circle.
Mr Scott's o-ring removal tool
I'll spare you the messy oil pics You all have seen old oil.
Aftermarket dipstick that can be read unlike the OEM one
2013 Ford F-150
3.5 Ecoboost V6
Out: Schaeffer's 9000 5w30, Motorcraft FL500S filter
In: Amsoil Signature Series 5w30, Motorcraft FL500S filter
2013 Ram 1500
3.6 V6
Out: Schaeffer's 9000 5w20, Mopar cartridge filter
In: Amsoil Signature Series 5w20, Napa Gold cartridge filter
'23 Kia Soul...10,023 miles; diy oil-filter change
out...whatever 0w-20 oil the dealership used at the 5k freebie oil change & blue Kia filter & crush washer on oil plug;
in...a mix of 0w-20 oils: fram 0w-20* x 1qt, quaker state 0w-20* x1qt, castrol gtx synthetic 0w-20** x 2.5qts & blue Kia filter & new crush washer on oil drain plug
* leftover 'top' off oil never used
** clearance oil -- $2 per qt from wallyworld earlier this year
2001 Ranger 4.0L
Out-5L of mag1 5w30 FS and a motorcraft fl820S (6,000Km OCI)
In-5L of liqui moly special tech 0w30 FS...with 15L leftover for the next three oil changes. I poured it into a leftover 5L jug for easier filling. Only made a small mess on the floor from doing it😂
2012 Chevrolet Silverado 2500 HD
6.0 Vortec V8
Out: Schaeffer's 9000 5w30, AcDelco PF48E filter
In: Amsoil Signature Series 5w30, AcDelco PF48E filter
2007 Buick Lucerne
3.8 V6
Out: unknown oil, Fram Extra Guard PH3387A filter
In: Fram Conventional 5w30, Swepco 502 Oil Improver, AcDelco PF47E filter
2015 Altima strippie; ex Hertz high mileage rental; 180K, 7.5K OCI; no make up added
Out: 4+ qts M1 + QS 0w20 Hi Mileage Frankenbrew
In: 5 qts Kirk 0w20, left M1 filter for next time
Oil level was above the add line.
Also swapped spark plugs, Denso TT out and in, 90K. Worn but all even, light soot. Looked great overall.
VC gasket time as there was oil in 2 of the 4 plug wells. Front brakes before too long.
You cannot kill this car.
2005 Chevrolet Impala
3.8 V6
Out: Mobil Super conventional 10w30, Schaeffer's Micron Moly EP, AcDelco PF47E filter
In: Swepco 306 Supreme Formula 10w30, AcDelco PF47E filter
1972 Chevrolet Chevelle
400 small block V8 with a mild cam
Out: Brad Penn Penngrade 1 15w40, WIX 51069 filter
In: Swepco 306 Supreme Formula 15w40, AcDelco PF1218 filter
2023 Volkswagen Multivan T7 2.0 TDI @ 3700 km (2299 miles) - dealer oil change
OCI @ 3700 km (2299 miles) and 3 months - first oil change
Out: factory oil, factory filter
In: Castrol Edge LL IV 0W-20 5.5 l (5.8 qt), OEM cartridge filter 05L 115 562 A, OEM oil drain plug N 908 132 02
I blame BITOG. Never before in my life did I thought to do first oil change so early.
Smart move. Your engine would thank you if it could.
Oil change on both cars…
2002 Saturn SL2, Napa Gold 51516, four quarts Mobil 1 ESP 0W-30, half a quart Mobil 1 Racing 0W-30. Replaced the oil drain plug…
2009 Smart, Wix XP 51356, four quarts Total Quartz 9000 5W-40
($7.38 a jug Advanced Auto clearance)…
Is the clearance back on? I got all my Total back in like June or July then they bumped the price back up
Wife’s 2016 Jeep Patriot 2.4; 63k miles:
Out: Castrol Edge EP 5W-20 plus a bottle of STP gold synthetic Oil Treatment and an OG Fram XG 10060 filter. Just over 7k miles and 13 months on both.
In: Castrol Edge 5W-20 (non-EP) and a Motomaster ‘OE Plus’ 10060 filter.
Used a coupon at work to get discount on OC while have new tires put on and vehicle oil sprayed for the winter. All set to go now!
