Post your latest oil change
Amsoil 0W-30 and filter same same 2017 CR-V T
'18 ACCENT is the same . Gotta be different than their rivals .
I don’t jack my Soul up, I use the jack to take some load off the front passenger side suspension, gives me a couple extra inches so I can shimmy under. Not too concerned about the few ounces I don’t get out. I still put 4 quarts in (3.8qt spec in manual). I actually like it up front, easier to get to.
It’s hard to tell but it’s just slightly over the F mark on the oil dip stick. 1.6L GDI
The '18 ACCENT read a bit higher after O.C.. Drawed out about 5 ounces through the dipstick tube and it's close to your reading .
Pump it out thru the dip stick
This will be going in 2014 Jeep Wrangler SportView attachment 151010
Just to bump this, this oil change will be happenning tomorrow. The Jeep's capacity is 6 quarts~5.67 litres. Would it be acceptable to use the remaining litre of Castrol EURO CAR 5W-30 ACEA C3 I have left over from last month's change on the Nissan to make up the small difference? Or just buy a single litre of the Mobil 1 0W-30 AFE and call it done?
Jeep has 26,000kms~16,000 miles on it currently.
Thx:)
Thx:)
I'd personally just use the leftover oil to top off your fill. Gets rid of that last little bit, and saves you from having to buy a single quart.
