Post your latest oil change
03 Buick Century (3.1)
Out Mobil 1 Extended Performance High Mileage-Mobil 1 Extended Performance filter
In Mobil 1 Extended Performance.High Mileage-Mobil 1 Extended Performance filter
03 Cadilliac Deville (4.6 Northstar)
Out Castrol Edge High Mileage-K&N filter
In Mobil 1 Extended Performance High Mileage-Mobil 1 Extended Performance filter
1998 GMC Jimmy (4.3) (first oil change as owner)
Out Castrol Edge High Mileage-Fram orange cheap filter
1996 F250 (351 Windsor 5.8)
Out Castrol Edge-Motocraft filter
All 5w30
2005 Bayliner Capri 175 (Mercruiser 3.0)
Out Quicksilver-Sierra filter
In Amsoil-Mercruiser filter
20w 40 i believe
Kids 2018 Jeep Compass
Out/In Havoline HM 5W30
Fram 10050(something like that, not sure of the number) In - Microguard $6.99 filter from O'Reilly's
Running fine and uses MUCH less oil than using 0W20 in it. Not sure if it has had the re-flash or not.
You're close. The Fram number on those is PH10060, crosses to an AcDelco PF48E.
Lol, thanks for that. I don't see the car often and it doesn't get treated the same as the stuff that lives here at the house (long story) but, at the same time, still want it to live a long life, and the basic stuff I get for it should be just fine. Main thing for me was slowing oil consumption since I don't see it often, and a 19 year old kid is hard to get trained on checking their oil on a regular basis.
2022 Hyundai Palisade
No, the one you mention is what my Accent uses. This is a more run-of-the-mill cartridge filter. Maybe other model year Palisade use the one with the pin too, not sure.
I’m probably thinking of filter for 2.5 engine that has flat looking gasket that slides down into groove.
Went through these until half blind - are you still running the Triax …?
Coincidentally, I changed it out today. Still not planning on running it again.
Todays oil changes - all 3 were fleet vehicles again:
2015 Ford Transit 250, 3.7L V6
OUT: Triax Synergy SRT 5w-20, Motorcraft FL-500S (7,230 miles)
IN: Pennzoil Ultra Platinum 5w-20, Motorcraft FL-500S
OUT: Pennzoil Ultra Platinum 5w-20, Motorcraft FL-500S (6,987 miles)
2020 Ford Transit Connect, 2.0L I4 GDI (NA)
OUT: Triax Synergy SRT 5w-20, Motorcraft FL-910S (6,231 miles)
IN: Pennzoil Ultra Platinum 5w-20, Motorcraft FL-910S
