Post your latest oil change
64 Ford Galaxie 390 V8
Out: Rotella T4 15w40, Protec 101 filter.
Same oil and filter going back in. I used the T4 3 gallon enviropack this time, I like the idea of it, but they need to make the boxes sturdier. I also found out the hard way you MUST turn the spigot valve back the way you turned it, it's not a 1/2 turn either way on or off like I thought it would be.
1985 GMC G2500 StarCraft Conversion van with 305 V8, 117,518 mi. OCI: 2,500 mi.
Out: Mystik JT-8 15w50 and Valvoline HM 10w30, High-end gold Fram FPS5 filter
In: 4 qts. Rotella T4 15w40 and 1 qt. Mobil 1 10w30, Champion-branded oil filter by Federal-Mogul (not sure who actually makes it, but it has a Wix-type model number 41060T). I got it for $1 at Dirt Cheap discount store.
2001 Toyota Tundra 4.7L 209K, 5,300 OCI, 16 month duration
Out: About 7 qts Kirkland 5w30, Mobil 1 301A filter (2 OCIs)
In: 5 qts Mobil 1 5w30 High Mileage + 2 qts Mobil 1 10w30 High Mileage, Mobil 1 301A filter
MityVac'ed most of the oil but pulled the plug when I swapped the filter. Maybe 1/2 cup additional came out but that always happens when you remove the filter.
I dropped the oily filter and splashed oil on my hair and forehead. Thank goodness I didn't get too much on the floor!
2001 Ford Crown Victoria
4.6 V8
Out: unknown oil, Motorcraft FL820S filter
In: Castrol GTX High Mileage 5w30, Motorcraft FL820S filter
2004 Toyota Sienna
3.3 V6
Out: unknown oil, Pronto PO241 filter
In: STP 5w30, STP S3614 filter
2019 Impreza Sport.
14,541 on car. 2,263 miles on Oil. Changed due to time. Should have been done at end of July but did it today. Put a few hundred miles on this week going to Cape May and back.
Out: Mobil 1 Extended Performance 0w20 and Subaru Filter.
In: Pennzoil Ultra Platium 5w20 and Subaru Filter.
First time using PUP. We'll see how it goes. I'm sure it will be fine.
Also changed cabin air filter with TYC ‎800208C.
2019 Kia Soul 1.6L Gamma GDI
Approx 27,100 on car, 2,950 on oil
Out: 3 qts Quaker State Full Synthetic 5w30, 1qt Valvoline Extended Protection Full Synthetic 5w30, Kia filter.
In: 3 qts of Pennzoil Platinum 5w30, 1 qt QS “All mileage” 10w40, Kia filter.
One bottle of Techron Complete was added a week before oil change. Tire pressure set to 35 psi.
Brothers 2016 Ram 1500 Hemi
183,680 on vehicle
9047 miles on this oil change, OLM @ 10%
Out: Mix of Mobil FS & RGT 5w20 and Fram TG10060
In: Mobil 1 5w20 and Wix 57060
Rotated tires and replaced Baldwin air filter which had approximately 45k miles on it with another Baldwin filter.
