Post your latest oil change
2001 Chevrolet Silverado 2500
6.0 Vortec V8
Out: Shell Rotella T5 10w30, AcDelco PF61E filter
In: Valvoline Advanced Synthetic 10w30, Napa Gold 1522 filter
2013 Chevrolet Malibu
2.4 Ecotec 4 cylinder
Out: Mobil 1 5w30, AcDelco PF457G filter
In: Royal Purple api 5w30, AcDelco PF457G filter
2008 Titan:
Out- Delvac/RGT, Lubegard
In- Rotella/RGT, Lubegard
Didn't change the oil filter this time around. Oil wasn't changed that long ago(3,004 miles) but was very dirty I'm guessing cleaning from the Delvac? Using some diesel oil to cut some 20 weight for this motor 👍
88,799 miles
2014 Chrysler Town and Country
3.6 V6
Out: unknown, unknown cartridge filter
In: Napa 5w20, Napa Gold filter (I dont remember the number)
1992 Pontiac Firebird
3.1 V6
Out: unknown, AcDelco PF47 filter
In: Fram conventional 10w40, AcDelco PF47E filter
'18 ACCENT ( 1.6 Ltr. , G.D.I. ) w/6 speed auto :
OUT : SHELL Rotella G.T. 5w-30 ( S.N.+, GF-5 ) + FRAM Ultra XG9688
IN : SHELL Rotella G.T. 5w-20 ( S.N.+ , GF-5 ) + NAPA Platinum 41334
2012 Prius C:
Out: ST FS 0w20
Off: Fram PH4967
In: NAPA FS 0w20
On: Fram PH4967
3,234 miles on oil over 7 months.
I planned to run the ST for a year but decided to OCI sooner than that.
I may or may not run the NAPA FS for a full year.
Time will tell.
10/09/2021 - 114459 mi on Nissan MR20DE engine in 2011 Sentra 2.0 S with new set of NGK spark plugs.
Out: Super Tech 5w30 HMFS SP. Off: AC Delco PF1237 filter. Only 1204 miles on oil and filter run since 06/27/2021 in temps ranging from mid-70s to 100+ on hilly, curvy streets in often heavy traffic in a city of 111k, so that's "severe service".
I have a road trip coming up next week, so wanted to get an OC out of the way.
In: Super Tech 5w30 All Mileage Synth Blend Non-Dexos SP. On: AC Delco PF1237 filter.
This OC went very well this time, unlike the previous 2. The filter came loose with just a quarter-turn of the filter pliers, then I loosened it more by hand and let it drain into the catch pan while I extracted the oil from crankcase with MityVac.
MityVac doesn't work as well as it used to, as I have to keep pumping it; if I stop, it goes for about 30 seconds and runs out of suction. I do remove the top to get out all remaining oil, so I must not be putting something back on correctly.
But at least the filter came off easier this time. I drove the car for around 15 mins, then let sit for about an hour. The previous 2 OCs, I did "cold" so, the filter was a bear to fight with.
Sorry guys and gals, no oil porn, forgot to snap the pics
Soon to be oil change before storage.
Out: M1 5W30 ESP AND Fram Ultra 6607 no wire backed media filter
In: M1 0W40 FS and Fram Ultra 6607 non wire backed filter.
ESP was rated at 11.9 Vst at 100 while 0W40 is rated at 12.6, a .6 diff when rounded no biggie. HTHS goes from 3.5(8) to 3.6. Went with this because the 40 has boron, more calcium and more zinc, LSPI isn’t a issue luckily.
The STP will go into the tank to stabilize the fuel even though I already pump 91 ethanol free.
Yes. The NA engine is very reliable and suitable for my driving needs.
When my dad was looking for an Escape I specifically made sure he got one with the 2.5L and neither of the EBs, there's not that many of them on the used market with the 2.5 versus the 1.5 or 1.6 ecoboost.
First oil change on my new Versa
Out: Factory fill
In: 4 Quarts Prime Series Full Synthetic 0w20
Oem filter
This oil change is me putting my money where my mouth is so to speak. After concluding any oil with the correct certifications will work for probably 95% or more of applications I decided to take my own advice. This is the cheapest oil I could get locally and not on sale. $18 for 6 individual quarts at Sams Club. D1G2 and API SP rated. So for $36 I get 3 oil changes.
The oil change went well. You never know how tight the filter will be on a new car but this one was fine. I didn't even jack up the car. I can reach the drain plug and filter just reaching from the front bumper with my long arms.
2017 Ford Escape, 2.0L Ecoboost
Odo at change: 121,572
Out: 4L Delvac 1300 15w40 +1 L M1 EPHM 5w-20 pre-doped with BioT
OCI Hours: 140
OCI Miles: 121,572 - 115,644 = 5,928
Off: Fram XG3600
Hours on filter: 135 + 82 +140 = 357
Miles on filter: 5,870 + 3,922 +5,928 = 15,720
In: 4qt Delvac 1300 15w40 +1 qt M1 EPHM 5w-20 + 1 qt SuperTech SAE 30 HD (SN+)
On: Fram XG3600
Oil changed at Walmart. They removed the drainplug to drain; unsure of total quantity drained and can't give feedback on dilution level.
Dipstick reads at the top of hash marks.
Odo at change: 126,282
Out: 4qt Delvac 1300 15w40 +1 qt M1 EPHM 5w-20 + 1 qt SuperTech SAE 30 HD (SN+)
OCI Hours: ~120
OCI Miles: 126,282 - 121,572 = 4,710
Off: Fram XG3600
Hours on filter: 120
Miles on filter: 4,710
In: 6qt of pre-blend (5qt QSE 5w-40, 1qt ETO2380, 1qt Traveller SAE 40)
On: Fram PH3600
