Post your latest oil change
2019 Ford Escape 1.5L EcoBoost, 4.5k on oil, OLM 0%. This was the first fill on a new short block, replaced under warranty due to internal coolant leak
Out: Motorcraft 5W-20, FL-910S
In: Mobil 1 Advanced Fuel Economy 0W-20, Bosch 72161WS
(The M1 was given to me by my neighbor—he had stocked up on it and then sold his only car which called for a 20 grade... thanks Carlos!)
2008 Hyundai Sonata 3.3 v6
Changed oil on my sister in laws car after replacing a valve cover gasket and o2 sensor.
Drained out Pennzoil 5w20 bulk oil from some oil change place. Cartridge so i couldn't tell what brand.
Put in Pennzoil 5w20 synblend yellow bottle and a regular fram filter.
Also changed oil on my f250 that i bought last fall and hadnt changed the oil because it looked fine and didnt use it much through winter
Removed napa gold filter, oil unknown
Put in the following
2008 Cadillac Escalade
6.2 V8
Out: Mobil 1 High Mileage 10w30, AcDelco PF48E filter
In: Castrol GTX Diesel 15w40, Schaeffer's #132, Napa Gold 7060 filter
1999 Pontiac Grand Am
3.4 V6
Out: Peak conventional 5w30, AcDelco PF47E filter
In: Traveller conventional 5w30, Purolator red L10111 filter
2006 Ford F150
4.2 V6
Out: unknown, Fram Extra Guard PH3600 filter
In: Valvoline Daily Protection 5w30, Napa Gold 1516 filter
#2 today; 2018 Chev 3500 D-Max L5P, out; the last free oil change with purchase at dealership, likely RT-4 15w40 AC Delco filter.
In; 15w40 T4 and Baldwin filter. Also spin-on trans filter.
#3 2007 1/2 Ram 3500 6.7L Cummins. out 15w40 fast lube ?? and Napa Gold filter.
In; Fram Ultra and a Franken brew of odds 'n ends.
75w90 Chevron in F&R diff.
Off 285/70/70 tires, on Cooper ST Maxx 295/70/18s on 18x9 wheels.
2012 Scion xB.
60,034 miles on vehicle, 5,006 miles on oil and filter.
1/2 qt low with no top off.
Out/off: Rotella Gas Truck 0W-20/Car Quest Blue (Wix) 84145 Filter
In/on: 4.5 qts Castrol Magnatec 0W-20/Bosch Distance+ 3422.
Total cost was qt for oil at AAP clearance).
For some reason, the last 2 Carquest filters have started leaking from the gasket area.
Not real bad, no sign on the ground where it it parked, but the filter was oily and the pan was as well.
Filter was plenty tight, no double gasket, no obvious damage to the mounting area, so no idea.
Will see if the D+ does it or not.
2021 VW Golf GTI with 6 quarts of Castrol Edge 5w30. Oil filter is OEM VW. Will replace plastic drain plug next time since I changed out the break-in oil at only 1000 miles.
Well you surely picked up a good deal on that I though I had a bargain at $16.
If that was to me, yeah, it was good, but her last change of Rotella Gas Truck and Carquest Blue filter was
Her next change will actually be either free or they will have paid me (free Mobil 1 filter from @DuckRyder a few years ago that I have yet to use and either some free Mobil 1 Advanced Fuel Economy due to Walmart pricing error or some Rotella Gas Truck that I was paid a few bucks for on clearance and rebate).
2011 BMW 328i xDrive.
Out: Castrol Edge 0W30 (sample sent for analysis).
In: Pennzoil Platinum Euro 5W40. As usual, MANN filter.View attachment 54986
I almost bought a used '14 a few years ago but went with a new Subaru instead. Had 2 Audis at the time and didn't want another expensive maintenance car. Your car sure does take a lot of oil. My B5 S4 takes about 8 qts but I have it modified with a second oil cooler and I am using the larger B6 A4 oil filter. Stock is about 6.5
2017 Chevy Malibu 1.5T GDI, 4,611 OCI, 40% OLM, 71k miles
Out: Kirkland 5w30 Syn, Wix WL10290
In: Same as out.
2016 Chevy Trax 1.4T GDI, 5,778 OCI, 25% OLM, 94k miles
Out: RGT 5w30, Mobil 1 M1C-257A
In: RGT 5w30, Wix 57674
I got this BMW in December 2019 with 84k, manual. Put 22k miles on it since and had so far only failed oil filter housing gasket ($37), which is a usual item on these engines, and I track this car.
The engine takes 7.5qt bcs. inline 6. They always take a lot of oil as 5&6 cyl cooling is more dependent on oil. Also, I retrofitted the oil cooler from 335 as I had oil temperature issues on track. So, now, it takes almost 8qt. That is good as these inline 6 also do not like high G load taking a left turn on the track. So, usually on track, people overfill a bit these engines.
