Post your latest oil change
Love the car. Manual states 0w-20 good for all temps or 5w-20 good for temps above -20F. Do you know better than Ford?
You mean CAFE I guess. I’ve seen plenty of ecoboosts failing due to thin oil, including my own one. They spec’d for 5w30 in Europe for a reason. Is that eco boost? 300hp+ on a regular SP oil sounds like a death sentence to me, but it’s your car. I’d at least run m1 esp 0w20
Boss and track pack Coyotes come factory filled with 5w50 and recommended by Ford as well.
Depending on how you drive the car will determine the best oil type. I think you'll be fine with your 0w20 fill.
Edit- Ecoboost or 5.0?
I don't think in my year ('18) they recommended 5w50 in any standard 5.0. I have the 5.0 GT Performance package level 1 which I think is the equivalent of what used to be called the track pack. It only recommends 5w-30 as an alternative if tracking the car. I'm sure I will be fine on 0w-20.
Now I'm sure 5w-30 would also work nicely, so I'm not saying that I believe it would be harmful. But for my application and usage, Ford recommends 5w-20 or 0w-20
2017 Chevrolet 3500HD (L5P Duramax)
23,326 miles and 1,118.2 hours total on truck.
OCI: 5,360 miles, 303.9 engine hours (11/29/2019 to 7/11/2020)
OLM showed 27% oil life remaining.
Out: Dealer bulk 15w40, AcDelco PF2232
In: 10 quarts of Delo 400 XLE 15w40, Mobil1 M1-303A
[Linked Image]
2017 L5P Duramax
28,394 miles and 1,406.3 hours on the truck.
OCI: 5,068 miles and 288.1 hours. (OLM @ 24%) In service from 7/11/20 to 4/9/21.
Out: ^
In:
Yes you are right. It must have been prior years and 2nd gen Coyotes.
The GT350 and GT500 recommends 5w50, but of course that is the 5.2L Voodoo(🤤) and not the Coyote.
Previous owner had it serviced with mc blend 5w-20 and it seems to have done it well. Crazy thing is that these cars have a 10qt sump
2008 Acura TL in signature (119,066)
Out -- 4.5 quarts of Pennzoil Platinum High Mileage 0W20 (2100 miles 2 years) and Fram Ultra
In -- FRANKENBLEND -- 1.5 quarts of PUP 5W20, 1/2 quart of PPHM 0W20, 1 quart of Quaker State High Mileage Syn Blend 5W20, 1 quart of RGT 5W20 and half of quart of Rislone High Mileage Engine Treatment & ST9688
Note+ very impressed with the cut and post of the ST9688 -- very confident this filter will be fine for a 5000 miles OCI !!!
What caught your attention Automechanic?
1980 Ford F100
300 inline 6
Out: unknown, a very old Motorcraft FL1A filter
In: 5 qts early 80s Union 76 High Performance 20w50, 2 qts early 90s Kendall GT1 Nitro 70, a very new Motorcraft FL1A filter
