Post your latest oil change
Mom's 2019 Hyundai Elantra
Out: Unknown oil
Motorcraft filter
In: Supertech Advanced Synthetic 5w30
OEM Hyundai filter
Easy change. Hyundai cuts out pretty decently sized holes to access the filter and drain plug. I did notice with the car on ramps the filter dribbled down the block and onto the plastic under tray a bit. Annoying!
2021 Tucson 2.0 Nu
Out: Factory fill / Hyundai filter @1300 miles. I just got the itch.
In: Mobil 1 10w30 / Mobil 1-104A (oil is currently $5.82 per jug at WM)
2001 Tundra Access Cab; 4.7, 204K miles, 5.4K and 1 year OCI
Out: Valvoline High Mileage, 6+ qts, left Mobil 1 filter (has 8K and 2 years)
In: Kirkland 5w30, 6+ qts
The MityVac sucked the pan dry. I only use the smaller tube in the dipstick tube, regardless of the car.
I used to think the MityVac was stupid, left too much oil in the pan, etc. I am now an Enlightened Rogue.
Zero make up oil; this thing runs like new. I will swap oil filter next service. Hope it comes off...
With the bigger filter, this is a perfect 7 quart service.
Jeff: It appears the relationship between oil filters and underwear is lost on you 🧐
My 2018 Taurus 3.5L turned 20k. Out with the old 5w20 RGT and Champion filter in with the same. I never ran oil or filter this far on anything I've own. Close to 6800 miles on oil and filter. Will report oil analysis when I get it back. Car feels so much smoother with a fresh oil change.
