Post your latest oil change
Friend's 2010 Nissan Frontier XE, 4 cylinder
72,136 miles
OCI: one year, 4161 miles
Out: Valvoline Maxlife 5w30, Hastings LF113 filter
In: Quaker State Advanced 5w30, LF113 filter
2001 Mercury Sable LS Premium Wgn. 3.0L Duratech 24v DOHC
224,418 miles
OCI 3 months around 3,000 miles (early as a flush)
Out Mobil Super Syn 5w30 with some Shell 5w30 make up, K&N 2010 filter
In: Shell RGT 5w30 w/ Liqui Moly Oil Saver, NAPA Platinum FIL 1372MP
Originally Posted by blufeb95
In my car 5w40 will be fine, if I change my dad's Bravada again before Winter I may put 0w30 or 0w40 in it, because he does a lot of short trips often. I have a house in Hartford City that I'm working on being able to move into, currently have a little problem with a cast iron sewage pipe seeping where it comes through foundation wall. Once I get moved in there and find a job I'll probably be working in either Muncie or Marion so I'll be driving 20-30mi trips in it, not to mention there's nothing in Hartford city so when you need to pick something up you can't find at a Dollar General or the Mom&Pop hardware store you have to drive to Muncie.
Unless Muncie gets down to -35 or below then the difference between a 0W-40 and a 5W-40 is meaningless. In fact the 0W rated oil might be thicker until then. The 30-grade will be thinner however, regardless of the winter rating.
Originally Posted by Benzadmiral
2016 Buick Lacrosse Premium
41,897 miles
Change at 3767 miles, January 3, 2020 to July 1, 2020; so only about 600 miles/month instead of my usual 900. Still had 31% life on the monitor.
Out: 5w30 Dexos certified Castrol Syntec; In: same
Filter: AC Delco
I plan to run this another 6 months, until December '20 or Jan. '21.
I guess your Da Swamp doesn't fill with ice in December or January. My oil changes here end in November - start back in April.
Too old to crawl under vehicles in the driveway in freezing temps. Not gonna' visit an oil change shop with my own oil and filter either in the winter.
2013 Civic LX, 1.8 litre, 86K, 6K OCI, 3 months
Out: 4 qts Mobil 1 0w20, left filter
In: 4 qts Mobil 1 0w20, left Fram XG7317 for 2nd OCI
Used MityVac for 3rd oil change. Altima, TSX, Civic. Easy $$.
I am getting sissified in my old age...
2019 Sentra 1.8
6 months, 2300 miles (not driven much with work from home ...)
Out: FF oil and factory filter
In: Supertech 0w-20 and Supertech filter.
Its a lease so it's not getting anything fancy. Even though I run it in my vehicles.
ML 500
140,000 km
Out: LM 5w40 @ 8000km/1 year with MANN filter
In: Pennzoil Platinum Euro 5w40 with MANN filter
Corolla
248,000 km
Out: Pennzoil Platinum High Mileage 5w30 @ 7500km/1 year with Napa gold filter
In: Pennzoil Platinum High Mileage 5w30 with a Fram Tough Guard oil filter (first time trying it)
Mom's 2018 Kia Soul, 27,766 miles on vehicle, 2,765 miles on oil over 7.5 months.
Changed for warranty reasons, and lots of short tripping (90% of driving is ~3 miles).
Out/Off: Valvoline Synpower 5w30/Prime Guard Filter
In/On: Delo 400 XLE 10w30/Supertech 9688
[Linked Image]
2017 Tahoe … 38k … 7k OCI
Out/off=Mobil 1 Annual Protection 0w20 & XG10575
In/On =6 quarts Mobil 1 Annual Protection + 2 quarts Mobil 1 Extended Performance (0w20) & PF63E
You know what you get when you mix Mobil 1 Extended Performance and AP ??
The highly sought after hydrid oil called Mobil 1 AEP...
Which stands for Advanced Eventual Potential
That Supertech Ecore filter is pretty decent for Mom's use. There's a cut-open one a couple pages back in the Oil Filters Room here. I know - I bought it.
Dr. Adam did the Surgery.
Yep, it's AEP and good for 17.5k.
2016 Honda CR-V SE 2.4L K24W9
79,512 mi.; OCI 5,684 mi.; MM
out: 4.6 qt. Pennzoil Platinum 0w20; Bosch Premium 3323
in: 4.6 qt. NAPA FS 0W-20; NAPA Platinum 47356
2013 Honda Civic 1.8L
OCI 5081 mi
Out: 4.0qt Castrol Edge 0w20, WIX 57356
In: 4.0qt Shell Gas Truck 0w20, Honda A01
Did a two-fer today, sisters and brother in laws vehicles.
2010 Hyundai Santa Fe, 178,470 on vehicle, 9,208 mile/1 year interval. Was down 1 qt.
Out/off: Valvoline Synpower HM 5w-20/Bosch D+ 3323 filter
In/on: Pento HP 5w30/Fram TG3593a
[Linked Image]
2004 Ford F150, 178,770 miles on vehicle, 1,997 mile/9 month interval.
Out/off: Magnatec 10w30 blend/Supertech ST2
In/on: Delo 400 XLE 10w30 blend/Supertech ST2
[Linked Image]
2013 Honda Pilot Touring 4x4
105k miles, around 5k mile OCI
Out: Supertech 0W20
In: Supertech 0W20
Wix 57356 replaced a Fram TG7317
Transmission drain and refill with about 3.5 qts of genuine Honda DW-1
Did the timing belt, water pump, plugs, and serpentine belt a few months ago. Other than being a bit gutless, this car has great - perfectly reliable and still looks and drives like new.
2002 Ford Focus ZTS, PowerWorks Supercharged (Eaton M62):
296,400 miles
OCI: 3,000 miles
Out: Supertech High Mileage Full Synthetic 0w20
SuperTech filter
In: Quaker State Ultimate Durability Full Synthetic 5w30
Ecogard X195 filter
