Post your latest oil change
2011 Nissan Sentra 2.0
Out: Unknown
In: SuperTech Full Synthetic 5W-20
Off: AC Delco PF1237 / Unknown EAF / Unknown CAF
On: Denso 150-2002 / Denso 1433591 EAF / Denso 4536017 CAF
2019 Honda CR-V 1.5T, 2100 miles
Out: Factory Fill, OLM at 30%
In: Mobil 1 Annual Protection 0W-20, Honda filter
New-to-me Jeep Grand Cherokee Overland, 3.6 V-6.
Out, whatever Jiffy-Lube used a month or 4 ago
In, 6 qts. Mobil 1 5W-28 and STP oil filter. Probably will use Wix next time.
"Meets Requirements VW505.00 and VW502.00"
Excellent price for the bundle. (Oil, Oil Filter, Air Filter)
Out: Unknown
to BITOG !
And...smart motor oil selection !
I've heard good stuff about the High Mileage version of Super Tech Synthetic 5W20.
Longtime lurker.
2018 Kia Stinger GT2
OUT: Pennzoil Platinum 5w30, Wix WL10237
IN: Pennzoil Ultra Platium 5w30, Wix WL10237
6000mi OCI. Blackstone report came back looking good.
So there isn't any confusion, this is my buddy's Passat. Mine has 0W20 in it.
2003 Buick Lesabre 3.8 L V-6 83K on unit 3K oci
Out 4.5 quarts Quaker State Ultimate Durability 10w30 and AC Delco PF47e filter
In: 4.5 quarts Quaker State High Mileage Syn Blend 10w30 and AC Delco PF47e filter
2016 Dodge Grand Caravan, 3.6 engine, 107K miles.
5 qts Pennzoil Platinum 5w20, 1 qt Pennzoil Conventional 5w30, Napa Gold filter
OCI according to oil life monitor. 10k miles this OCI
Originally Posted by Blue_Goose
2018 Honda Civic HB 1.5L 55k
Out : Castrol Syntec 0W20 Fram Ultra 7317 9300ish miles
In : Rotella Gas&Truck 0W20 Fram Ultra 7317
About 3 1/2 quarts
That Honda only holds 3-1/2 quarts and you ran the oil for 9.3k?
If that were mine, I'd disregard the owners manual and disregard any used oil analysis and change the oil at one-half of your 9.3K.
That's assuming your Honda will be with you a lifetime. If not, then just roll with Supertech - then discard the vehicle prematurely to old age.
About 3 1/2 quarts
I don't think it's unreasonable. Seems to be enough oil for, basically, a 1.5L lawn mower engine. Cubic inches devided by Qts.
My 1984 Pontiac 6000 2.5 held this low amount. I ran it to almost 300k using conventional every 3K. It's death was rust, not oil-related.
It ran perfect and the dipstick was still amber semi-clear, as I drove it to the junkyard 18 years later. Too dangerous to sit-in. I recall paying $8k for the new Pontiac. Now the new, similar Malibu / Honda loaded is closer to $28k.
Oil is still cheap in comparison. Costs pennies really to change a little more frequently. There wasn't any nickels and dimes used to buy that Honda. Why nicke and dime the oil change frequency?.... unless the vehicle won't hang around a lifetime and if that's the case, then why not use trusted Supertech?
1996 Jeep Cherokee 4.0L 4x4. Ran this last oil change for 27 months and 4,908 miles. Oil filter was on for 37 months and 7,765 miles.
Out: Mobil 1 High Mileage 10w40 & Fram Ultra
In: 5 quarts Rotella Gas Truck 5w30, 1/2 quart Pennzoil Ultra 10w30 (circa 2013, non-natural gas) & Wix filter
2018 Mazda6 26,796
Out: motorcraft 0w20 Full Synthetic and motorcraft filter
In: motorcraft 0w20 Full Synthetic and a fram XG
Also switched out my set out continental dws06 tires that has 5K on them that I couldn't get rid of the vibration for a set of general g-max as-05's. Tires ride 100% better. Sending oil out for oil sample here this week.
Wow
Those General g-max as-05's are rated real well at Discount Tire. Thanks for the post, as I will folder this brand & model for the future.
I also have the Kumho Crugen HP71s and Michelin Defenders in that folder.
About 3 1/2 quarts
55K on the clock and running like a charm. I usually don't keep a car for more than 2-3 years anyways but I may run this one into the ground when it hits 400K. I avg about 36K a year. Working remote cut into this total big the last 3 months. I'd say 90% of that mileage is highway as commute is 100 per day ayg r/t. My ex's 2010 Honda Fit was still running like a top at almost 300K before she traded it for a 2019 Civic Touring Coupe.
Also fwiw, I haven't noticed any gas smell in the oil and the dipstick level appeared to be steady even after 9K. Warranty on engine to 125K. I'm comfortable
