2002 F150, 200,014 miles on truck, 3,414 mile/13 month interval with 2 qts makeup oil:
Off and out: Bosch Distance+ and Magnatec 5w-20 (with 1 qt Mobil 1 EP 0w-20 @ 1,300 miles and 1 qt QSUD 0w-20 @ 2,500 miles, truck was 1/2 qt low when changed).
On and in: Mobil 1 M1-210A filter and for oil, 1 qt QSUD 0w-20 and 5 qts PP 0w-20 (figure same viscosity and are both SOPUS products, will be just fine).
Plan on a ~3,000 mile interval again. I do a lot of short tripping, and drive less than 3,000 miles in a year in it.
I have debated never doing another oil change on the truck since I use a qt of oil every 1,200-1,500 miles.
I have a Fram Ultra on my shelf, maybe next year I will put that one on and just do a 4 year run without changing the oil or filter, just keep adding oil.
Also did an ATF drain and fill, hence the MaxLife ATF.
