Post your latest oil change
I did an oil change in my wife's BMW tonight and it was the end of an era, I put the last of my supply of German Castrol into it
All I have left now is two 5L jugs of Belgian made Castrol 0w40 and then after that, I will switch the car over to Mobil 1 ESP 5w30, because Canadian Tire no longer carries Castrol 0w40 at all.
Originally Posted by mpack88
No other 5w40 will do?
I don't really want to run a 5w40 in this car, most of them are too thick compared to what I've been running in this car (either Mobil 1 0w40 or Castrol 0w40) Besides, now that ESP 5w30 is sold in 5L jugs up here, and goes on sale frequently, it's reasonably priced and it's an oil I can use in both the BMW and the Corvette (once my supply of the old ESP Formula 5w30 runs out that is)
Serviced my moms car.
2008 Mercury Mariner 3.0L 152,081 miles
OLM was at 7%
Out: Mobil 1 5w20
Motorcraft FL820S
In: Mobil 1 High Mileage 5w20 Purchased from Walmart
Wix 51372 Rockauto
17 Tundra 5.7
35,165 miles
5100 miles on oil
OUT- Rotella Gt 0w20 TRD filter
IN - Rotella Gt 5w30 TRD filter
2018 VW Golf Sportwagen. 1.8. IS20 turbo/Unitronic Stage 2 software.
Out - 5.8L Liquimoly Leichtlauf High Tech 5W40 + MoS2 additive + VW filter
In - 5.8 Liquimoly Molygen 5W40 + VW filter
Flushed with Liquimoly Proline Engine Flush prior to change.
Virgin analysis sample take as well as before and after flush used oil for analysis....interested to see how it looks! Just trying the more gimicky Molygen for [censored] and giggles.
Let us know how the engine flush did.
My oil change this weekend
2017 Mercedes C43 AMG
Out - Pennzoil Platinum Euro 5w40 + MoS2 additive + MB OEM Filter (Purflux)
In - Pennzoil Platinum Euro 5w40 + Purflux Filter
[Linked Image from i.ibb.co]
got some catching up to do....
my 18 Mazda6 touring 22K out: super tech 0w20 and Super Tech filter.....in: motorcraft Full Synthetic 0w20 and fl816 motorcraft filter 5K oil change interval.
dads 11 edge sel 129K Out: motorcraft 5w20 and fl500 filter..... in: Super tech 0w20 and Super Tech filter 5K oil change interval
my 15 Focus S lemon law car 66K Out: motorcraft 5w20 and fl910 filter..... In: Super tech 0w20 and fl910 filter 5-6K oil change interval
aunts 10 focus 86K Out: unknown oil and microguard filter....In: super tech 0w20 and Super Tech filter..... also did plugs and valve cover gasket along with front brakes.
2010 Mercury Milan 2.5L Hybrid
Out: Napa Proselect SFI 21348 Pennzoil Platinum 5W-20 In: NAPA Platinum Filter PFL 41348 / A new Drain Plug/ Mobil 1 Annual Protection 0W-20
2002 F150, 200,014 miles on truck, 3,414 mile/13 month interval with 2 qts makeup oil:
Off and out: Bosch Distance+ and Magnatec 5w-20 (with 1 qt Mobil 1 Extended Performance 0w20 @ 1,300 miles and 1 qt Quaker State Ultimate Durability 0w-20 @ 2,500 miles, truck was 1/2 qt low when changed).
On and in: Mobil 1 M1-210A filter and for oil, 1 qt Quaker State Ultimate Durability 0w-20 and 5 qts Pennzoil Platinum 0w20 (figure same viscosity and are both SOPUS products, will be just fine).
[Linked Image]
Plan on a ~3,000 mile interval again. I do a lot of short tripping, and drive less than 3,000 miles in a year in it.
I have debated never doing another oil change on the truck since I use a qt of oil every 1,200-1,500 miles.
I have a Fram Ultra on my shelf, maybe next year I will put that one on and just do a 4 year run without changing the oil or filter, just keep adding oil.
Also did an ATF drain and fill, hence the MaxLife ATF.
10 Hyundai accent
1.6 4 cyl
Out: unknown, stp filter
In: napa 5/20, napa gold filter
06 Chevy cobalt
2.2 4 cyl
Out: Quaker State Advanced Durability 5/30, fram filter
In: napa 5/30, napa gold filter
07 caravan 2.5l 161,xxx
Out: Pennzoil conventional bulk 10w30
In:. Vpb 10w30
93 Dakota 3.9 4x4 80k
Out: vdb 10w30
In:. Vpb 10w30
Charokee 225+k
Out: Quaker State Conventional bulk 10w30; past due amount near drain
In:. ST sae30 cf/-2, stp, mmo, and st8a
