Post your latest oil change
my wife's 2007 chrysler town and country
out: 5w30 havoline and the purolator filter
in: 5w30 havoline and a mopar filter.
I was feeling generous and even changed the air filter.
2015 Tacoma 4.0 with 1147 on oil change (6 months). I do not drive it that much, total miles on truck is 6068 and it is 2 years old.
Out: Pennzoil Platinum 5w30 with OEM filter
In: Mobil 1 0W30 with OEM filter
2004 Pontiac Grand Prix GT 3.8L V6 (son's car)
Out: SuperTech 5w30HM, SuperTech filter
In: Quaker State High Mileage (synblend) 5w30, Supertech filter
OCI: Unknown, but beyond the OLM by a few months. Oil was BLACK. This is one tough engine. . .
2008 F150 King Ranch 5.4l 3v v8 (108k)
OUT (5k oci) - Pennzoil Conventional 5w30, Motorcraft 820s
IN - MileSyn blend 5w30, Motorcraft 820s
2005 Ford Econoline E350 Super Duty short bus, 6.8 V10, auto, RWD
Out: Motorcraft semi synthetic 5W-20, Motorcraft FL820S filter
In: 7 QTS ACDelco semi synthetic 5w30, Napa Proselect 21372 filter
97 F250HD in my sig.
7.3powerstroke / 4EOD / 4.10 / 2x4 / 221,200miles
Out: 10qts of Pennzoil Platinum PurePlus / Pennzoil Ultra euro 5w-40, 1gal Mobil 1 Extended Performance 0w20, and Purolator. 1yr / 12.8K, unknown amount of make-up(15w-40)
In: Lube King hdeo 10w30 and FL-1995
2005 Ford Escape 3.0, my brothers.
out: I think he was running Formula Shell 5w20, with a Wix made Carquest filter
In: Hastings made Federated filter and Quaker State Ultimate Durability 5w20
2012 Mitsubishi Galant w/2.4L. Just purchased two weeks ago. 116K miles. Had sticker from Wal-Mart TLE for previous oil change. OCI at 4400 miles.
Out - Castrol 5w-20 with Walmart Tire and Lube Express Fram filter. (assuming Castrol GTX but sticker just indicated Castrol 5w-20)
In - Pennzoil Platinum 5w30 w/Wix 57092 and new Wix Air Filter. Will change some transmission fluid in a couple of weeks.
2013 Honda Accord EX-L V6 with six speed manual transmission and 3.5L engine. 45,941 miles on the ticker with 9531 miles on this OCI with 5% Maintenance Minder remaining.
Out - Four quarts Honda Ultimate Full Synthetic Oil, 0W-20.
In - Same as above.
Also will use the same oil filter for the second oil change interval, a Mobil 1 I bought at an estate sale for four dollars several years ago. I will post a C&P dissection of said filter next OCI, say sometime early 2018. Four bucks for a quality filter, not a bad deal.
Originally Posted By: JavierG
2016 Honda Civic EX-T Coupe: 7192 OCI
Out: Factory Fill and Original Filter
In: Pennzoil Platinum 0W20 and Bosch Premium Filter
I'd shorten that OCI or get a used oil analysis at 4k.
2001 Toyota Tundra 4.7L
Out: Carquest 5W20 and Blue Mountain Filter (short run after valve cover gasket change)
In: Mobil 1 5W20 and MC FL400S with it being longer than the stock size FL910S I can put in a 7qts instead of the listed 6.5qts.
Did my friend's 2004 Ford Explorer Sport Trac on Monday. 178K miles.
Out: ~5000 miles on unknown quick lube dino w/ some undersized FL500s-equivalent jobber filter- I forget the brand.
In: One of Walmart's $8 5Q jugs of Valvoline Synpower 5w30, Motorcraft FL-820s (mfrd. January 11th, 2017)
I missed almost a year's worth of changes, but here's an update:
2017 Hyundai Santa Fe Sport 2.0T, Factory fill/filter (out) - two changes, both Hyundai bulk semi-syn 10w30, OE filters
2011 Toyota Sienna LE V6, Quaker State Ultimate Durability 0w-20 Syn, Toyota OE (out) - two changes, first Mobil 1 0w-20 Syn with Toyota OE, and then Pennzoil Platinum 0w20, Fram Ultra
2011 Lexus RX 350, 63,331KM. Also did brakes on all four corners. Pads were less than 4mm.
Out:
Mobil 1 Advanced Fuel Economy 0W-20
M1C 251 Filter
In:
5L Castrol Edge 0W-20
1L Castrol Magnatec 0W-20
M1C 251 Filter
New-to-me 2009 BMW X5 3.0i xdrive
86xxx miles
4k miles OCI to get a known OCI starting point
LiquiMoly Engine Flush for mild varnish/unknown OCI history
Out:
Unknown oil/Carquest filter
In:
Castrol Edge A3/B4 0W-40(LL-01)/Mann HU816X
Will leave in until OM goes off(15k mi), or 1 year. Maybe even fall/winter OCI if I can't wait any longer.
Also changed Power Steering reservoir/filter and new Pentosin PS fluid. Fluid was REALLY dirty.
