Post your latest oil change
2012 Chevy 2500 6.0 Vortec 112k miles
Napa Blue Bottle 10W30, Federated PG2222F filter
drain plug torqued to 18 ft lbs
1999 Dodge Ram 2500 5.9 Magnum 169k miles
4 quarts Napa Blue Bottle 10W40, 1 quart Lucas(owner swears by it) Baldwin B34 filter
drain plug torqued to 25 ft lbs
2014 Ford F-150, 5.0L V8
27,517 miles on vehicle
7,338 miles on oil & filter
26% oil life monitor
OUT:
Valvoline MaxLife SynBlend 5W-20
Motorcraft FL-500S
IN:
Pennzoil Platinum Full Synthetic 5W-30
FRAM Tough Guard TG10575
2015 Subaru Legacy 2.5L
30K on unit/ 5K oci
Out: PPP 0W-20 and Wix 57055 filter
In: PPP 0W-20 and Wix 57055 filter
2012 Jeep Patriot 2.0L w/ CVT - 61,967 miles. ~2,600 miles & ~5-6 months on OCI
Out: Quaker State Advanced Durability 5w20 & Microguard filter
In: Castrol GTX SynBlend 5w30 & Microguard filter
2005 Camry 4 cyl 163XXX miles
Out Chevron Supreme 5w-30
In 4 qts Chevron Supreme 5w-30
Champ PH2840 filter
Will go 3000 - 4000 mile OCI
Usually 3 months
Regards,
Scott
2000 Buick Regal 3800SC
out Rotella T-5 10W30
In Valvoline Conv 10W30 and a bosch filter
valvoline conv was my 4.00 dollar 6 pack from walmart for winter storage I'm going to prep it to be put away for the winter
car came from Georgia , has never seen salt or snow since day 1
2005 Chevy Classic 2.2 Ecotec
4 quarts Autozone Dexos 5W30, 1 quart Supertech Dexos 5W30 (both made by WPP)
Baldwin P7442 filter
Drain plug and filter cap torqued to 18 ft lbs
Out: PYB 10W30 and OE S2000 PCX oil filter - 3k OCI
In: PUP 5W30 and Mobil 1 M-110 oil filter
OLM showed 60% before I changed the oil. I know it's early but it's getting cold here (changing the oil outside, in walmart parking lot and it is a PITA if it's colder than 10C). Also I started to drive more on highway which I usually see 4000-4500 rpms regularly. So decided to switch back to synthetic. Will use it for 7k+ miles.
