Post your latest oil change
Some more OCIs used for about 100 hours each. Once a year OCI.
Toyota Forklift 7FGU15
Out: Pennzoil Platinum 5w30, Wix 57145
In: Castrol 0W-40 A3/B4, Splash of Pennzoil Conventional and Pennzoil Platinum 5w30 max 1 ounce each, Wix 57145
Toyota Forklift 7FGU18
In: Castrol 0W-40 A3/B4, Wix 57145
Originally Posted By: Oregoonian
Originally Posted By: wemay
wemay said:
2013 Hyundai Santa Fe Sport 2.0T
Out: Pennzoil Platinum 5W30
In: Mobil 1 0W30
3,000 or 6 months
IMO.....you are highly under-utilizing a top-tier synthetic. What a waste. should be able to do at least 7500...on Mobil 1 or Pennzoil Platinum.
If your intent is doing only 3000 OCI's (old school)...just save $$$ and go to a conventional.
He has a car under warranty, it calls for oil changes every 6 months. Why does it bother you if he spends an extra $7 twice a year for synthetic?
Because its a stupid waste of resources....I dom't crre if he spends extra $$$, but its still for stupid reasons. USE A CONVENTIONAL.....at 3000 OCI's.
A few points...
This veh gets as much or more conv oil as syn
Nick1994 is correct (warranty)
Driven under sev svc schedule (3k/6mts)
On the other hand, my Corolla does indeed go 10k/1yr between changes under normal sev schedule.
...and i really could care less that you find my reasoning "stupid".
In: Mobil 1 0W30
3,000 or 6 months
Correction: not 0w40
+1
Waste of resources? If an oil change takes 5 quarts and he changes 2x a year, that's still 10 quarts of oil a year, conventional or synthetic. Maybe he has reason to believe a synthetic will protect his engine better? Synthetic oil can withstand high temperatures better, start better in cold temperatures, and some might argue it lubricates better.
10 quarts of oil is 10 quarts of oil.
Is buying a name brand Tide laundry soap a waste of resources, rather than buying a generic one that will still get the job done?
2007 Toyota 4Runner 1GR-FE 131k miles
Out:
5.5qts Mobil 1 High Mileage 5w30/Toyota YZZD3
In:
5.5qts Valvoline Maxlife red bottle 5w30 / PureOne 20195
2014 Nissan Versa Note
Out Pennzoil Gold Blend 5w30 and Microgard filter
In NAPA Full Synthetic 5w30 and Purolator Filter
3000 plus or minus, miles
2013 SC`d Nissan Titan 2wd
out: AMSOIL Signature Series 5w30 w/OEM Nissan mexican made filter
in: Amsoil XL 5W30 w/Fram TG7313
OCI 2718
Truck had multiple Dyno pulls for ECU tuning, then road testing.
2011 Chevy 1500 4.8 Vortec, 120,219 miles on truck, 5,750 miles on oil/filter
Out: Castrol Edge HM 10W30, Fram XG10060
In: Supertech Dexos 5W30, Baldwin B160
drain plug torqued to 18 ft lbs
oil was sent off to Blackstone, first ever UOA for this truck, one owner since new
2005 Kia Picanto 1.1 LX
139300 miles
Out Petronas EU 800 10w40
In Castrol Magnatec 5w30 A5/B5 SN
Probably just under 2k miles on the Petronas.
Was used as more a a clean up oil as didn't know when the oil was last changed.
I have reused the old filter due to the low number of miles I have done.
Nissan Qashqai 1.6
out something + Filtron filter
in Shell Helix Ultra 0W40 + Wix filter (Mann filters were out of stock)
2004 Chevrolet Cavalier, 2.2 4 cylinder, auto
Out: Castrol GTX HM 5w30, Fram Core filter
In: 5 QTS Coastal Semi Syn, Napa ProSelect 27082 filter
1967 Chevrolet Camaro, 396 BB V8, auto, RWD
Out: Castrol Syntex 10w30, Havoline T-45 filter
In: 5 QTS Delo 400 15w40, Napa Gold 1069 filter
2016 Toyota Rav4 with 2.5 litre engine
Out: Mobil 1 Advanced Fuel Economy 0W20 and Toyota 04152-YZZA1
In: Mobil 1 Advanced Fuel Economy 0W20 and Toyota 04152-YZZA1
2014 Chevrolet Silverado 5.3 L
25K on unit/5K oci
Out: 8 quarts NAPA 0W-20 Synthetic and AC Delco PF63 filter
In: 8 quarts NAPA 0W-20 Synthetic and Purolator One PL22500
(Living on the Wild Side with the install of a Tear-O-Later....wish me luck)
Six month/5000 mile maintenance. 2004 Camry V6. Five quarts of Mobil I 0W-20 and OEM oil filter. Inspected internals of oil filter removed and everything looked new. Never see a pleat out of place, deformed or broken on an OEM oil filter. Works for me and has for twelve years. Think I will drain AT next week or so and use MaxLife ATF.
