Post your latest oil change
2013 Impala 3.6 V6, 104k miles
Castrol Edge Extended Performance 5W30, Federated Auto PG2500F
drain plug torqued to 18 ft lbs
OLM run down to 0%, even though its a direct injection engine thats hard on oil, the owner runs it to 0% despite me saying different and he hasnt had a problem
2013 Carolina Skiff 218 DLV, 2013 Yamaha 200 4 cylinder outboard, my dads boat, 107.5 hrs
20W40 Yamalube oil, Yamaha oil filter(made by Denso)
new washer on drain plug, torqued to 20.5 ft lbs
also foot oil changed with Yamaha sae 90/80W90 gear oil
engine and foot oil changed every 100 hrs, this previous oil had 87 hours on it after the break in oil was changed at 20 hrs
2016 Chevy 2500HD 6.0 Vortec 9,397 miles
Napa Synthetic Dexos 5W30, Baldwin B160 filter
bosses truck thats used in very dirty, dusty conditions, changed every 5k
2013 Hyundai Veloster R-Spec.
Out - Pennzoil Platinum 5w30 ran for 4k miles
In - Mobil 1 5w30
Hyundai OEM filters both runs. Will finally be sending in for a used oil analysis for the Pennzoil run to see how this DI turbo is doing.
**2010 Ford fusion 2.5L 99,679 miles
Out: 5Q of Pennzoil Platinum PurePlus 0w20
In: 5Q of Mobil 1 Advanced Fuel Economy 0w20 and left the fram ultra on for another oil change.
*It was a 7k interval with about 12% left on the OLM.
*also did a tire rotation along with a drain and fill with 4.5Q of maxlife atf.
**2008 Ford Escape 2.3L 159,146 miles
Out: 3Q of Pennzoil Platinum PurePlus 0w20 and a napa gold filter.
In: 4Q of Quaker State Ultimate Durability 5w30 and a TG3614.
*it was about a 7k interval with about 14% left on the OLM.
*also did a tire rotation along with a fram air filter.
All wheels torqued to 100ft pounds.
Daughters 2016 KIA Soul 1.6
OUT.
Factory fill 5w20
Factory filter
IN.
Mobil 5w20
KIA filter
4994 miles
Neighbor's 2010 Honda Accord 4 cyl. auto w/77,501 miles
OUT: Castrol 5W-20 Fram silver with black grabby rubber filter (as in NOT orange)
IN: Castrol 5W-20 MANN-HUMMEL PureOne 14610 in the fancy angled box
+ a new 14mm aluminum washer.
NOTE: Found a screw in the RR tire when I rotated them. This impressed my neighbor.
HERO-of-the-DAY: Found the spare had 8 psi and I filled it.
2010 Traverse. 146,969 miles. Valvoline Synpower 5w30 and Bosch 3334 filter. About 5,000 since the last oil change at 50% oil life. Not quite convinced of going 10,000 or so by the OLM with the 3.6 having a history of worn timing chains.
Have 2 cars with the 3.6, 5K is my change interval due to the timing chains you mentioned
2006 Colorado Z71, 3.5L I-5, 97k mi, 9k OCI, Oil life monitor started flashing yesterday AM. So, after work:
Mobil 1 Filter
4 qt T6 5-40
2 qt Pennzoil Platinum High Mileage Synthetic 5-30
2015 RAM HEMI 5.7
Out: Pennzoil Platinum PurePlus 5w20 Wix Filter.
In: Pennzoil Platinum PurePlus 5w20 Mopar filter.
OCI 8.8K miles.
08 Chevy Silverado
Out: Quaker State Conventional and Microgard filter
In: Mobil 1 Advanced Fuel Economy 0w30 and Mobil 1 filter
02 Honda Civic
Out: Pennzoil Ultra Platium 5w20 and Fram TG
In: same
2012 Ford Focus
Out: Pennzoil Platinum 5w20
MC FL910S
7K miles
In: NAPA Synthetic 5w20 (Sale stuff for $2.99)
MC FL910S
