Post your latest oil change
2012 Toyota Rav4
21,300 miles on engine
7000 miles on oil and filter
Out
Mobil 1 0w20 AFE and Toyota filter
In
Mobil 1 0w30 AFE and Toyota filter
2007 Ford Fusion with a 10K OCI. Engine still remains very clean through the oil fill hole. Oil use was 4-5oz.
Out: M1 0-20 AFE
In: M1 0-20 AFE
Filter: MC FL 2017B In and out.
2006 Pontiac Vibe AWD
Doing short OCIs to clean out the sludge. Change oil based on cleanliness. This time it took 2k miles to get dirty. Last time it was like 1200 miles or so. Anyways.
OUT: Delo 5w40 and Purolator L20195
IN: Mobil Super Synthetic 0w20 and Motorcraft FL400S
So far so good:)
2 cars done yesterday
2001 Mazda Protege 6k miles on oil
Out: MS5k 10w30 and a Purolator 14612
In: Supertech 5w30 and a Puolator 14612
2002: Pontiac Grand Prix 2800 miles on oil
Out: Carquest 5w30 AC delco PF47E
In: QuakerState green bottle 5w30 Champion PF47E
2001 ES300, 198,XXX miles.
Out: Pennzoil Ultra 0w-40 with 1500 miles, Purolator Boss PBL10241 w/ ~2900 miles. Will cut open later.
In: The choice of my $2 autozone quarts- 3 Quarts Pennzoil Platinum Euro 5w-40, 2 Quarts Pennzoil Ultra 5w-30
With a new Super Tech ST3614.
Short intervals are over, planning on running this for a more normal 5 or 6k miles.
2007 Honda TRX420 Rancher (ATV)
OUT:
Whatever oil & filter were in it, they'd been in WAY TOO LONG.
IN:
Castrol ACT-EVO X-TRA 4T Motorcycle 10W-40 Synthetic Blend
K&N KN-113 cartridge oil filter
First oil change in a new--- to me---- 2002 Toyota 4Runner
170,000 miles, 3.4L V-6
Out: According to the sticker it was Castrol GTX 5W-30
In: 6qts Valvoline Maxlife SemiSyn 5W-30, Fram TG filter... will run this first change
4-5k miles
today
2012 GMC Canyon 3.7 96,500 miles
Drained out factory oil out the rear diff
Painted cover high heat black, torqued all bolts to 25 ft lbs and filled it up with Amsoil Severe Gear 75W90. Should be good for another 100k
1993 Saturn SL2
Yesterday, performed a piston soak. Step 1, PB Blaster. Step 2, Rislone Engine Treatment Concentrate. Multiple spins with the starter, then left it overnight.
Today, drained the oil and filled up with Valvoline NG 5w-30 and a bottle of Motor Medic flush. Idled for 15 minutes. Drained and refilled with more Valvoline. Idled that for 7 minutes.
Drained and then installed a new PSL20195. Filled with ~2.8 quarts of Mobil 1 TDT 5w-40, a quart of MMO and a bottle of STP HM.
The old oil and filter (FL-400S) had 6201 miles on it. I will cut the filter some time soon and provide pics.
'96 Jeep Grand Cherokee 109,679KM
Out:
Oil: Unknown
Filter: Full OPH253, wrong filter...
In:
Oil: PYB 10w-30
Filter: Hastings LF115, oversized filter.
2008 Dodge Dakota SLT 4.7 4x4 70,0000 miles. Out Castrol GTX 5w20 conventional and Fram Extra Guard oil filter.In Quaker State 5w20 conventional and Fram Extra Guard oil filter
1991 Lexus LS400
out: Total Quartz 9000 Energy 0W30 + WIX WL7172
in: Shell Helix Ultra 5W40 + WIX WL7172
2010 Hyundai Elantra, at 102,205 miles. Using a Motorcraft filter, and a mix of weights (using what I had on hand), 1 qt 0w-20, 1 qt 20w-50, 2 qts 5w-20, for an approximate average close to 10w-30 (or 7.5w-27.5 if the bottled weights are exact). Brands used: Valvoline, Supertech, and two quarts O'reilly store brand.
ATF drain and fill, 3 qts of Valvoline Maxlife, compatible with the SPIII requirement.
This vehicle was purchased used, at about 70,000 miles. Prior to now, I'd always use 20w-50, with the logic that thicker oil would be superior in my hot climate. Now, I'll follow the manufacturer's recommendation of 5w-20, 5w-30, or 10w-30, given what I have learned since then.
08 Silverado: Out: Formula Shell and Ac Delco filter
In: QSGB and Microgard filter
04 Impala Out: QSGB and Carquest red filter
In: Castrol synblend and Microgard filter
02 Civic Out: QSGB and QS filter
In: QSGB and QS filter
03 Nissan Fronter 2.4 4cyl
4k oci
out:
50% m1 tdt 5w-40 api sm
25% g-oil 5w-30 api sm
25% m1 ep 5w-30 api sn
in:
75% qs defy 5w-30 api sl
25% penzoil ultra 5w-20 api sn
Reused the xg7317
