Post your latest oil change
03 Frontier 4cyl
91k miles on the odo
6.6k oci
Out: 5w30 goil xg7317
In:
Frankenbrew
1qt. - 5w30 goil
1qt. - Mobil 1 Extended Performance 5w30
2qt. - 5w-40 Mobil 1 Turbo Diesel Truck
New xg7317 filter.
1992 Buick Roadmaster Estate Wagon, 5.7 TBI V8, Auto, RWD
Out: Presumably Kendall GT-1 Full Synthetic 10w30, Firestone TF454 Filter
In: 5 Qts. Quaker State Advanced Durability 20W-50, 300ml Liqui Moly Mos2, Napa Gold 1069 Filter
Car has been resurrected after a two year hiatus, had a rather raucous engine noise on the old oil, hence why it was parked. So, thick QS, LM MoS2,and possibly STP is the regiment now. Engine noise has been significantly reduced and has great oil pressure.
2011 Dodge Avenger 2.4
85,718 miles
OCI - Estimated at 4kish miles - completed previously by local quick lube center. Lots of short trips - neighbor's niece's car
Out - 3.0 qts (drain plug leaking) of Mobil Special 5w20 and Security Global oil filter L10060.
In - 5qts of Havoline Conventional 5w30 and AC Delco PF63 and a new crush washer.
2002 Ford Expedition Eddie Bauer 5.4L
290,886.7Km (180,748.6 miles)
OCI: ~10,000Km, in service from September 14th, 2014 through to March 6th, 2016.
Out: Pennzoil Ultra 5w30 w/Motorcraft FL-820S
In: Motul 8100 0w30 w/FRAM Ultra XG2
2015 Ford F-250 Super Duty, 6.2L gas V8
9,850 miles on vehicle - 5,108 miles on oil/filter
All towing miles, OLM 6%
OUT:
Valvoline SynPower 5W-20
FRAM Ultra XG2
IN:
Pennzoil Platinum 5W-20
Motorcraft FL-820S
Planning to change again in 5K-6K miles.
Also had to replace the air filter already, it was very clogged. Replaced the factory Motorcraft air filter with a FRAM Extra Guard.
96 jeep grand cherokee 4.0 weekend toy/offroad toy
out: napa 15w40 & puro classic ( less then 3k/10 months)
in:
2 qt napa 10w30 SN
1qt Pennzoil Conventional 10w30 SL
1qt Valvoline 5w20 from around 2005-2007
1qt oreilly 20w50
1qt peak 5w30
driveworks oil filter from aap closeout
wanted to use up my single quarts that didnt really 'belong'
the jeep never gets up to operating temp unless its going on an offroad adventure, so oil wont see many miles, no more then 3k if i do that this year
today
2008 Nissan Frontier 4.0
Mobil 1 10W30, Wix 57356, 156k miles, 6-7k oci
Changed rear axle seals and bearings on my Ranger also so the rear end got 2.5 quarts of Amsoil Severe Gear 75W90 along with a new Fel-Pro diff cover gasket.
I don't think bud_one cares. Quick lub monkeys run drain plugs up tighter than a snare drum and mechanics like me get stuck replacing whole oil pan!!
2015 Ford Focus ST
18,000 on the car, 8,000 miles on the oil.
Out - 3 qts Mobil 1 Extended Performance 5W30 / 3 qts Mobil 1 0W40
Amsoil EA034 filter
In - 3 qts Amsoil Sig Series 5W30 / 3 qts Amsoil Sig Series 0W40.
Amsoil EA034 filter.
07 Dodge Caliber. 160k. 5K OCI. Out, a blend of Mystik 15w40 and Peak 5w20 at 50/50, both from sales, literally 5.00 worth of oil. Purolator white can. Back in, same thing, except a Purolator red can. This car does not use a drop of oil during an OCI, is quiet, and has been running some type of HDEO blend for the last 100k.
2014 Ford Fusion Titanium AWD 2.0L EcoBoost 17033mi.
out: Mobil 1 5W30, Motorcraft FL-910S
in: Mobil 1 0W40, Motorcraft FL-910S
OCI was right around 7k miles.
today
2013 Chrysler 300 3.6 Pentastar 66k miles
Pennzoil Ultra Platium 5w20 Wix 57526 filter
2005 Dodge 2500 5.9 Cummins, 303k miles
Mobil Delvac 15W40, Napa Gold 7620
2003 GMC Sonoma, 61k miles
Napa conventional 10W30, Napa Gold 1040
Originally Posted By: mjoekingz28
Bud One,
They have a drain plug sealant available on the register rack at some parts houses.
I'll keep an eye out for it next time.. thanks for the heads up
2001 Toyota Celica GT
100,745 original miles
Out: Unknown bulk oil/Toyota oil filter
In: Havoline High Mileage 5W-20/Fram Extra Guard PH4967
6 months, 4,457 miles on OCI. Oil looked literally brand new on the dipstick before the oil change, no darkness at all to be seen. Oil was always changed every 3k on the dot by the previous owner, sometimes as early as 1.5k. One of the very few 00-02 Celica GTs that does not burn a drop of oil, probably due to the perfect maintenance by the previous owner.
