Post your latest oil change
2004 F-150 5.4 3V 148K
Out: Pennzoil Platinum 5W-20
Filter: Motorcraft FL-820S
OCI: 7k
In: Pennzoil Platinum 5W-20
Filter: Purolator PSL24651
OCI: 8-10k
2002 Chevy Malibu
Mobil 1 5w30
Fram Tough Guard oil filter
1 bottle of Techron added to fuel tank
7500 mile oci
Out: Same as above
2003 Honda Civic LX AT
39,315 miles
SuperTech ST3593A
Mobil Super 5000 5w20
This last run was longer than my usual- ~9,500 miles, about a year ago I ran synthetic.
About this "Maint Req'd" light: it goes off every certain number of miles, correct?
Any advice on my oil change schedule/which oil I should use? The car sits for most of the year as I live in a bicycle-friendly neighborhood. But I'd like to keep it sharp. I felt bad with the extended OCI because of the synthetic, but was that appropriate?
Thanks.
2001 Mazda 626 V6
137,250 miles
Out: Castrol GTX HM 10w30, Denso Filter
In: Castrol GTX HM 10w30, Microguard Filter
Miles on oil: 4,000
Main rear seal is still leaking, but the GTX HM has slowed it to the point of not being an issue, or at least not worth the money to fix. Over 4,000 miles I used 1/2 quart of oil.
2010 Chevrolet Traverse AWD
Current Mileage: 52,587km (32,676 mi)
Most recent OCI: 4 months and 8672km (5388mi) with OLM showing 47%
Drained: MotoMaster Formula 1 Synthentic (4.4L) + 1L Mobil 1 5W30
Filled: Formula Shell Conventional Oil 5W30
Filter OFF: ACDelco PF48
Filter ON: ACDelco PF48
2010 Ford Fusion Sport 59k
Out: Amsoil XL 5w-20, Motorcraft filter
In: Pennzoil Ultra 5w-20, Fram Ultra
5%OLM/1yr OCI
2005 Lexus IS300 125k
Out: Mobil 1 Extended Performance 5w30, Bosch Distance+
In: 2qt Toyota 0w-20, 3.7qt Mobil 1 0w-40, Purolator Synthetic
7500/9month OCI
1998 Dodge Neon SOHC 156k+
Out: Pennzoil High Mileage 5w30, Purolator Classic
In: Valvoline Conventional 5w30, Purolator Classic
4 month OCI
1996 Nissan Sentra 1.6L 150k
Out: ???, Fram Extra guard
In: Valvoline Conventional 5w30, Fram Tough Guard
5000/6month OCI
2006 Nissan Altima 103K:
Out: Castrol 5w30,Nissan filter,4K OCI
In: Valvoline 5w30 WB, Nissan filter
KingCraft 3250 Generator:
Out: Oreillys 10w30 80+hrs
In: Peak 10w30
2005 Silverado 77K:
Out: Motorcraft 5w30,Motorcraft filter...dealership $22.95 special
In: Valvoline 10w30 WB, Purolator filter
2004 Jeep Grand Cherokee I-6, 107k
Out: Castrol GTX High Mileage winter blend of 5w20/5w30, MoS2, Motorcraft FL-400S.
In: Quaker State Defy 5w30, MoS2 and Fram Tough Guard TG3600.
Fourth consecutive OCI with MoS2, UOA pending.
1986 vw campmobile. 1.9l H4 watercooled.
in: summer blend; 3 qts shell rotella 15w40 + 1.5 qts kendall Semi Synthetic 10w40ish (1 qt 5w30, half qt 10w50)
out, 1 gal of winter blend 30 weightish, at 163700 mi. memo: next due at 168k
2013 Sonata 2.4L in: Valvoline 5w20 conventional ($12.88 WM deal), out Pennzoil Platinum 5w20 ($19.88 WM deal), OC @ 12,789 kms, next OC due at 18,000 kms.
OEM Hyundai filter.
On the Hyundai Canada 4 month or 6,000 km OCI interval.
So far Valvoline conventional as smooth and as noise free as the PP.
2004 Highlander:
Out: 4 quarts Quaker State Ultimate Durability 5w30 Napa Gold Filter
In: 4 quarts frankenbrew - Mix of .5qt 5w20 PZ, 1qt Quaker State Ultimate Durability 5w30, 1qt T6 5w40, and the remaining Chevron 5w30. (Thinking of going straight T6, opinions?)
Also D/F Auto trans - 3 quarts maxlife ATF, and D/F power steering with Maxfilfe ATF too
142,374 Miles on Vehicle.
Just changed my '13 Hyundai Tucson GLS today with Pennzoil Platinum and a Hyundai oil filter. I ended up picking up 0W-20 and didn't realize that it called for 5W-20 until I had already drained the oil. Oh well, I don't think it will hurt anything and I'll go with 5W-20 next time.
