may I know your reason for using 0w20? I believe 1nz-fe calls for 5w30. Just curious because I also have a 3door 2008 yaris and just sold my 2000 Taurus (also calls for 5w30) and now have a newer Forester that calls for 0w20. So maybe I can simplify oil purchase and I'm just gonna use 0w20 with the Yaris. The Yaris doesn't burn oil and I believe still in the break in period with only 170k kms on the odo. By the way,OCI on my daily Yaris. Out came Total Quartz 0w20 and a FUG. Oil was in for an odd interval with about 4k on it, filter has 10.6k on it. In went Toyota filter and SuperTech High Mileage Synthetic 0w20.
Can I ask what was the reasoning for the 5w50?GF's 2006 Fiat Punto II with 40k miles
out: Mobil 1 Rally Formula 5W50 + Filtron filter
in: Mobil 1 0W40 + Bosch filter
Could be placebo effect but after oil change the engine just purrs happily and is really quiet.![]()
Car is bone stock.Can I ask what was the reasoning for the 5w50?
Is it tuned?
I have always had great results with Mobil 1 0w40 but haven’t had a car that I could use it in for a while.
Ive been using 0w20 since 1500miles when I drained out the factory fill. I use it for better gas mileage. I tried 5w30 once about a year ago and had noticed reduction in overall fuel economy. Went back to 0w20 and it came right back. So I just stick with it. I even occasionally track and autoX it. Car has just under 191k on it currently.may I know your reason for using 0w20? I believe 1nz-fe calls for 5w30. Just curious because I also have a 3door 2008 yaris and just sold my 2000 Taurus (also calls for 5w30) and now have a newer Forester that calls for 0w20. So maybe I can simplify oil purchase and I'm just gonna use 0w20 with the Yaris. The Yaris doesn't burn oil and I believe still in the break in period with only 170k kms on the odo. By the way,
where did your get that tanabe strut bars? Thanks.
I tried using thinner oil in my daughters Kia Picanto years agoIve been using 0w20 since 1500miles when I drained out the factory fill. I use it for better gas mileage. I tried 5w30 once about a year ago and had noticed reduction in overall fuel economy. Went back to 0w20 and it came right back. So I just stick with it. I even occasionally track and autoX it. Car has just under 191k on it currently.
My other 1nz car I use 5w30.
2014 Subaru Forester 6MT 2.5L NA2014 Subaru Forester 6MT 2.5L NA
ODO: 121,000
Consumed: ~0.8 qt
Top up: 0.5 qt
Miles on oil: 121,000 - 117,361 = 3,639
Estimated hours on OCI: 3,639/30 = 121.3
Out: 4.0 quarts blend (3 qts Delvac 1300 + 1 qt Mobil 1 Extended Performance High Mileage) + 1.5 quarts blend (3 qts NAPA 20w-50 + 3 qts NAPA SAE 40 + 3 qts Quaker State Euro 5w40 + 1 qt ETO2197)
In: 5.0 qts Frankenbrew of consolidated leftovers from many jugs/blends
Off: N/A; XG7317 round 2
Estimated hours on filter: 121.3
Miles on filter: 3,639
On: N/A; XG7317 round 2
Got a cut in the inner boot of a CV axle I just put on back in April.
Replaced the CV axle, then did the oil change.
Also discovered where some noise is coming from--passenger rear wheel bearing sounds to be going out.
Catch can is still catching a good bit of oil still.
