Post your latest oil change
2014 Buick Verano T, 2.0L GDI turbo
79200 miles total
6000 miles on oil
Out: Mobil 1 European Car Formula 5w40.
In: Mobil 1 High Mileage 10w40. Walmart was out of ECF.
No filter change.
20% left on OLM.
Oil sample taken.
Ouch. May have made a mistake buying Mobil 1 High Mileage 10w40. Its KV100 is only 12.6, and I think I need about 14.0 to avoid dropping out of grade on a long OCI. Will probably dump it at 4000 miles. The current 10w40 HM is barely at the bottom of the 40 grade. It used to be on the thick side of the grade. Fool me once, Mobil, but not twice.
79200 miles total
6000 miles on oil
No filter change.
20% left on OLM.
Oil sample taken.
I thought it was 15cst?
2013 Bmw X5 35i xdrive 4,413mi OCI. Changed early due to upcoming road trip.
Out: Quaker State Full Synthetic 5w-40; Mann HU816X filter
IN: Valvoline Euro 5w-40; Mann HU816X filter
2013 Hyundai Elantra, 1.8, 4,176mi OCI. Used more than it typically does on Pennzoil, almost 2qts.
Out: Pennzoil Platinum 5w30; Supertech ST9688 filter
IN: Valvoline Extended Protection 5w30; Supertech ST9688 filter
I looked up the spec sheet on the Mobil website, and it said 12.6. I thought it must be a mistake, but that's what it says.
https://www.mobil.com/en/lubricants...roducts/products/mobil-1-high-mileage-10w-40/
Then I tried to look up the spec sheet for 5w40 ECF, and couldn't find it, even though I looked it up before my previous oil change.
This is what I get when I look for the 5w40 spec sheet:
I sense a government plot. Everybody's oil viscosities seem to be near the bottom of their respective grades these days.
2014 Subaru Forester 6MT 2.5L NA
ODO: 114,353
Consumed: ~1.5 qt
Top up: 1.0 qt
Miles on oil: 114,353 - 110,151 = 4,202
Estimated hours on OCI: 4,115/42 = 95.5
Out: 4.5 quarts mix (3 quarts Supertech 20w-50 + 2 quarts Traveller SAE 40 + 4 quarts Quaker State Euro 5w40 + 1 qt ETO2197)
In: 5.5 quarts blend (3 qts NAPA 20w-50 + 3 qts NAPA SAE 40 + 2.5 qts Quaker State Euro 5w40 + 1 qt ETO2197 + 0.5 qt Biotech)
Off: XG7317
Estimated hours on filter: 95.5
Miles on filter: 4,202
On: XG7317
Changed the rear differential oil and transmission oil as well this weekend.
Transmission out: unknown, PO's blend (looked red and transparent and didn't smell typical, maybe RL 75w90 NS?)
Transmission in: Motul Gear 300 75w90 GL-5
Miles on oil: unknown, est 40,000 .... (910 hours, minimum est)
Drain plug was well coated up with metal, maybe 3 mLs?
Differential out: Supertech 80w90
Differential in: 3 parts Supertech 80w90 and 1 part Redline shockproof lightweight
Miles on oil: roughly 40,000 (910 hours)
Drain plug wasn't too covered with metal, but the oil came out looking kinda dark. Kinda like Cola without the redness.
ODO: 117,361
Consumed: ~0.5 qt
Top up: 0 qt
Miles on oil: 117,361 - 114,353 = 3,008
Estimated hours on OCI: 4,115/42 = 100.3
Out: 5.0 quarts mix (3 qts NAPA 20w-50 + 3 qts NAPA SAE 40 + 2.5 qts Quaker State Euro 5w40 + 1 qt ETO2197 + 0.5 qt Biotech)
In: 4.0 quarts blend (3 qts Delvac 1300 + 1 qt Mobil 1 Extended Performance High Mileage) + 1.5 quarts blend (3 qts NAPA 20w-50 + 3 qts NAPA SAE 40 + 3 qts Quaker State Euro 5w40 + 1 qt ETO2197)
Off: XG7317
Estimated hours on filter: 100.3
Miles on filter: 3,008
On: XG7317
I moved and changed jobs right prior to doing this OCI; My commute averages 30mph instead of 40mph now, and has been reduced to 40mins one-way. This is the lowest consumption rate I have experienced yet. Started to drive harder, and consumption picked up to something noticeable, and so I went back to my previous driving style to run out the CI. The oil level remained at the top of the dipstick up until around 2,400 miles into the OCI when I did such test. Oil came out darker than I thought it would.
2008 Dodge Grand Caravan 110000 miles
Out: Valvoline 5w30 HMFS and a Fram Ultra unknown miles on OCI because I forgot to log the mileage at time of change
In: 1 qt HPL Engine Cleaner 40, 4.5 qts amsoil marine and diesel 15w40 and .5 qt of Valvoline PBE 5w40 with a Purolator Boss.
Will run this for entire OCI and change filter at 2k miles
Wife's 2017 Acura MDX Elite with 117 000km
Out: Total Quartz FS 0W20 Fram TG7317 filter
In: Pennzoil Platinum FS 0W20 Fram TG7317 filter
OCI: 12000 km 10 months. MID at 30%, but leaving on a west coast trip next week so decided to get the change done early. No make up oil needed.
My 2012 Acura TL Tech with 170 000km
Out: Valvoline High Mileage FS 5W20 Filter ST9688
In: Supertech Full Synthetic 5w20 Filter ST9688
OCI: 11700 km 10 months. MID shows 20%. Used about 1L between OCI as there is rear main seal leak. Might fix it next year.
Also, both MDX and TL called for rear differential fluid swap also (B16 service) so they were done at the same time. MDX got Acura DPSF and TL got 50:50 of Acura DPSF and Honda's version. It was a busy fun day.
2011 Subaru Forester
Out: Kirkland 0W20 and Mazda N3R1-14-302 filter
In: Kirkland 0W20 and Wix 57830 filter
2019 Subaru Crosstrek
In: Kirkland 0W20 and Champ PH2867 filter
Time to build a hoard of 15w-50.
