Post your latest oil change
2006 Tacoma 2.7L, 179k odometer miles
Out: PUP 5w30 and WIX 51516 filter (oversize)
In: NAPA (Valvoline) 5w30 full syn and WIX 51516 filter
Notes: 5900 miles on this service interval, shorter than usual due to some nasty camping roads and some hauling too. Not much else to say, modern synthetic oils hold up well and truck runs awesome.
1985 GMC G2500 Vandura Starcraft Conversion, 305 V8 with bad valve seals, 115,100 miles
Out: 4 qts Rotella T4 15w40, 1 qt. Mobil 1 10w30, Wix 51061
In: 4 qts Mystik JT-8 15w50 synthetic blend (in a Rotella container), 1 qt Valvoline MaxLife 10w30 synthetic blend, Fram Ultra FPS5
OCI: 2,500 mi.
2013 Suburban 5.3L, 129,700 miles.
5,700 miles and 6 months on oil. OLM at 3%. Topped off with about 1/4 qt late in the OCI.
Mobil 1 0w-40 FS and OG Fram Ultra XG10060 out and in.
2013 Suburban 5.3L, 124,000 miles.
6,300 miles and 6 months on oil. OLM at 18%. No oil consumed or added.
Out: Mobil 1 0w-30 AFE, OG Fram Ultra XG10060
In: Mobil 1 0w-40 FS, OG Fram Ultra XG10060
2002 Silverado K2500(Sons truck) 68k miles
Out and off: Kirkland 5W30 and Napa gold filter
4150 miles and change oil light came on.
In and on: Kirkland 5W30 and one quart of QSFS 5W30 with K&N filter
used my 1” end wrench for the first time ever to snug filter
2013 Scion XD, about 67k miles
OCI 3100 mi., 8 months.
Out: Valv. Adv. 0W20, Wix filter (was in for 2 OCI's)
In: Same, with a cartridge AC Delco filter from my filter stash. Don't recall buying that one. Looked pretty cheesy, somewhat undersize O ring. Made in China. Used it anyhow.
2005 Subaru Baja in Signature (115,408)
Out -- 4.5 quarts Chevron Supreme Synthetic Blend 5W30 SP and ST6607 (5028 miles)
In -- 4.5 quarts RGT 5W30 SN and ST MP6607
Took the Subaru to Cape May New Jersey for the week for vacation. From last Friday till this morning. Ran a bottle of Gumout Regane HM Fuel System Cleaner for the way down and back. Changed oil this morning after mowing the grass while still on vacation till Monday July 11th 2022.
Ps... Baja is short tripped 85% of the time and used locally for errands. Wanted to stretch its legs for a good drive and heat things up well.
2017 Mazda CX-5 2.5 SkyActiv. 20140 miles.
Oil had just over 5000 miles on it.
Out. Idemitsu 0W-20
Mazda Roki filter Thailand.
In. Valvoline EP 0W-20
Mazda Value filter. Wix Mexico.
Job took 90 minutes. I’m old and slow plus thorough.
I'll be there by October. Did your oil level drop or was the oil have a little gas whiff to it from the DI? It was a nice cool morning here in the PNW for an oil change. How much of that time was due to the belly pan anti DUI factor the manufactures have burdened us with?
Out. Idemitsu 0W-20
My BIL Mark Johnson lives in Gig Harbor. I bet you 2 have a lot in common. He's a good wrench. He's retired and has tons of energy; he would love to do an oil service with you. Seriously. Mark cannot sit still, unlike me.
It did have a good whiff of gasoline to it. No oil level drop at all nor a increase.
The belly pan is easy. Two push pins and two bolts for the access panel. I spray a bit of lithium grease onto a paper towel and clean the bolt threads while the oil is draining. Hit the hood latch as well.
Don’t tell me you took the whole belly pan off?
I don’t mind it. The weather was perfect today. I take my time mainly to double check myself.
I’m the guy who walks into the grocery store then tries to figure out why I went there in the first place. So I double check that everything is cinched up good. I would never make it in a quick lube place.
