Post your latest oil change
2020GMC Sierra AT4 with 3.0 Duramax; 7 Quarts ACDelco 0W20(Dexos D) with .5Q Schaeffers Moly EP and a PF66 Oil filter. 43k miles and last UOA using the same materials was very good after 6k miles or 20% on the OLM. In the summer I run Schaeffers Euro Spec 5w30, same filter but no Moly. A very good oil for the small diesel...only 0.8% SAC. Made for diesels with DPF's.... https://www.schaefferoil.com/documents/288-8008-td.pdf
12 Civic 1.8, 113K
Out: Mobil 1 Extended Performance 0w20, Honda oil filter, 2557 miles
In: same
10 C300, 72K
Out: Mobil 1 0w-40, Mann oil filter, 4900 miles
In: Mobil 1 0w-40, Genuine MB oil filter
16 E350, 165K
Out: Mobil 1 0w-40, Mann oil filter, 10,719 miles
2008 Ford Escape: 3.0 V6 189,258 miles.
Out: 6 quarts of Valvoline High Mileage 5W-20. Off: Motorcraft FL-820S.
In: 6 quarts Motorcraft 5W20. On:FL-820S
Found the pan gasket to be the source of the leak. Will replace the pan gasket sometime in the summer it’s just too darn cold to do it now lol. Cleaned it up really good with brake cleaner and degreaser and let it run and that’s where it’s seeping from some spots little more than others. Was strongly suspecting the timing covers to be the source as it’s common on these 3.0 after age. Also for some reason the drain plug likes to seize on this thing so I had to use a long 1/2 ratchet to get it off ended up rounding the drain plug on one corner because I don’t have a 15mm 6 point 1/2 shallow socket at home and the 1/2 to 3/8 adapter with the 3/8 socket was too long to fit in the area so I had to just use the 1/2 drive socket with the ratchet. The plug was already a little bit rounded on that one part but i finished it off this time lol. At least it still goes after you hit it on a little. So I’ll replace that next time.
2004 Toyota Camry 2.4 I4 272,315 miles.
Out: probably 3 quarts of Valvoline High Mileage and 2 quarts of Pennzoil High Mileage. Started with 5 quarts of Valvoline but it’s an oil user. Off: Toyota 04152-YZZF1
In: 5 quarts Napa 5w30. On: Purolator 14477 filter. I know the capacity is not quite 5 quarts but we put all of it in because it will burn about a quart in 1,000 or so miles.
2010 Ford F-150 5.4L 3v V8, 61,962 miles.
Out/Off: 5qts Citgo Synthetic Blend 5W-20 & 2qts of a mixture of 5W-20 and 5w30, FRAM PH2 oil filter.
OCI: 2,983 miles, since Sept 2021. Most of the time this truck is short tripped or idling.
In/On: 5qts Pennzoil Platinum 5W-20, 2qts Formula Shell 5W-20, Motorcraft FL-820S oil filter.
2015 Fusion 2.0l ecoboost, 6,743mi oci
Out and off: RGT 5w30 and PL10241
In and on: same
2016 Edge 2.0l ecoboost 6,166mi oci
Out: Rotella Gas Truck 5w30
In: Pennzoil Platinum 5w30
Left the xg3614 on. It’s the last wire backed one I had so figured one more oci wont hurt.
2021 Jeep Wrangler 3.6 Etorque, 9,124 miles
Out: Supertech Advanced Full Synthetic 0w20, Mobil 1 filter
In: Mobil 1 Extended Performance 0w20, Fram Ultra filter
The factory fill on my wife's 2021 was in there for about 4400 miles (We bought it used) and I put the Supertech in there intending a short 2k or 3k run to continue to clear out the residual materials from assemble and break-in. I decided to leave it in there for 5k, but we had warm weather today so out it went with about 4600 or so on it. I'll run the Mobil 1 until it hits about 15k miles and settle into 5k OCI's from there on out.
I want a Rubicon sooooooooooooooooooooooo bad! But alas, no Rubicon for me.
2017 Nissan Rogue, 2.5L 4cyl. Dealer 0W20 and Nissan 15208 65F0E out, and Pennzoil Platinum 0W20 and Mahle OC575 installed. Drain plug torqued to 26Ft-Lbs.
Decided to start doing the oil service myself, my wife was against this when it was under warranty, but I can do this work for $45 CAD versus $79 CAD at the dealer. Very easy car to change the oil, the engine block has a nice cast lip at the oil filter that directs the draining oil away from the car, my Infiniti soaks my subframe with oil each time the oil filter comes off.
GMC Yukon 2019 5.3L
Out: ACDdelco 0w20. ACDelco filter
In: Mobil 1 fs 0w40. ACDelco filter.
Nissan Altima 2014. V6
Out: Unknown oil and filter (brother did the change last time)
In: Castrol Edge Black 5w30. Nissan Filter
2007 Toyota pickup truck with more than 360k miles
Out: Toyota oil 20w50. Toyota filter.
In: Fuchs 20w50 (Fuchs is one of the best oil brands but it almost not exist in US and Canada for passenger cars.) Toyota filter.
VW 2022: Oil and filter is changed by dealer because it comes with servicing for the first 30000 miles. I think they use Shell last time. I'll probably try the 5W40 Mobil 1 or Fuchs after that.
Sons 2002 Jeep Liberty with 188,000 miles on it. 3.7 liter V6
Out — Quaker State Ultimate Durability 5W30 with 5,000 miles on the oil. Oil was LOW AND DIESEL BLACK. Fram filter
In — 5W30 Super Tech and Fram filter.
