Post your latest oil change
Is that oil and filter from an old stash?
I have not seen any D+ filters at any stores since the Walmart clearance years ago, and I know I got a bunch of that 5w-20 Magnatec in qt bottles on clearance from Advance Auto a few years ago as well.
I got the distance plus at Walmart on clearance.
The magnatec I got at a local fleet farm on clearance. I have several 6 quart cases yet along with Castrol edge
2014 Buick Verano (2.4 ecotec)
51,875 miles
Out: unknown oil, unknown interval (OLM @ 7%)
In: Mobil 1 EP 5w30, Fram XG9018
2016 F150 2.7 ecoboost
39000 miles
Out: Schaeffer’s 5W30 Supreme 9000 and Motorcraft filter
In: Schaeffer’s 5W30 Supreme 9000 and Motorcraft filter
2006 Jeep Liberty:
Out: dealer stock (Castrol) Motorcraft filter
In: Supertech 5W30 synthetic high mileage and Motorcraft FL400s filter
39000 miles
2006 Jeep Liberty:
This should have said 8,900 miles on the oil.
2021 Subaru Forester 6200 miles on vehicle
2100 miles on oil and filter
3rd oil change, all with Amsoil SS 0W20
At 2000 miles I replaced the front and rear differential gear lube with Amsoil severe gear 75W90 and the engine oil and filter.
OUT: Amsoil SS 0W20 with Subaru Tokyo-Roki oil filter.
IN: Amsoil SS 0W20 with Subaru Tokyo-Roki oil filter.
I'm sending an oil sample to Blackstone at this oil change.
2013 Sonata 2.4L 57K
Out: 5.4 qts Mobil 1 EP 5w20 12,450 miles on this run in only 5 months. I simply lost track of the miles on this and will not happen again.. XG filter
In: 5 qts of Mobil 1 EP synthetic 5w30 and 0.9 qt of Valvoline advanced synthetic extended protection 5w30 and a prefilled oem oil filter.
Book says 4.8 qts in reality it’s 5.9 quarts after a one hour drain to bring the oil level up to the full mark on the dipstick. I stick to 6K max oci on the 2.4l’s except this past run that i’ve lost track of miles and doubled it. 🤦‍♂️ Had to mix a new quart of Valvoline synthetic ep on this change since Walmart was out of M1 5W 30 ep qts.
Next oil change will be all Valvoline advanced 5w30. 🎉
@09 GLS
Just out of curiosity, you mentioned that your Sonata requires 5.9 qt (vs the stated 4.8) to reach full after draining. Does the dipstick show full when the 5.9 qts are hot or cold?
2015 Mazda 5 at local shop. 135,000 miles. Cam2 0w-20....I didn't get chance to chat with him why the switch to Cam2. But, I can safely assume it is cheap, bulk, and good enough...
It's a Synthetic Dexos 1 Gen 2 Oil. Likely way better than you are giving it credit for. I doubt he has 0W-20 in a bulk tank. It likely came out of a bottle. Dealers where the manufacturer specs it now are the only ones I've seen with it in a bulk tank.
@09 GLS
Hot or cold it makes very little measurable difference on the dipstick reading. To note the Sonata 2.4 has orange dipstick while the Kia 2.4 has yellow one. And they both take about an extra qt over book to bring to full mark after a extended drain. (5.9 qts sonata 5.4 qts kia.) The sonata has 4.8 qts written under hood while the Kia has 4.5 qts.
2013 Ford F-150 V6 Ecoboost with 99,942 miles. OLM at 57%, approximately 4,400 miles.
OUT: 6 qts. 5W-30 Motorcraft Syn Blend & FL-500 filter.
IN: Same
Got a free 1st oil change from the Ford dealer. Originally asked for 100K service, but, previous owner had everything replaced before I got it. Saved over $500. 😁
You are correct. I just never heard of Cam2 and will learn about it. My local shop guy is good and wouldn't offer low-quality junk to customers. He and his crew are auto enthusiasts on the side who understand the finer details of the trade and apply that to their pro work. I really could simply trust the work they do... but, I just want to know and understand things.
2005 Toyota Tacoma 4.0
221k on truck
Out: 5qts Mobil 1 5w30 high mileage and .5 qts Schaffers Supreme 9000 5w30
In: 5qts Valvoline Maxlife 10w30 FS and .5 qts Schaffers Supreme 9000 5w30
Running Fram Ultra 3614 OG for 2nd 5k OCI
Also have been using Liqui Moly Motor oil saver each OCI to help with occasional blue puff on startup
Did some oil changes this week
2012 Honda Fit
Out: Valvoline HM 0W20/ Fram TG7317
In: Castrol Edge HM 0W20/ OEM filter
Not sure how many miles on it but the light came on. Pretty sure I forgot the oil light last time but eh
2020 Mirage 7114 miles
Out: Valvoline FS 0W20/ TG7317
In: Castrol 0W20/ Castrol 7317 filter
2012 Avenger 157k miles
Out: QSFSHM 0W20/XG10060
In: QSFSHM 0W20/ Purolator PL1222
2012 Maxima
Out: Castrol Edge HM 5W30/Fram Titanium 6607
In: QSFSHM 5W30/ PL14612
Used up all my Castrol stuff from the Black Friday deal. Probably gonna go back to Quaker state since it's pretty cheap at Menards.
