Post your latest oil change
2005 GMC Yukon Denali AWD
6.0 lq4 V-8 engine
Odometer reading: 153,000 mi
Out: 6 quarts of unknown oil and an AC Delco filter
In: 6 quarts of Valvoline Advanced Full Synthetic 5w30 and a Fram Tough Guard 3506 oil filter
Total product costs: $36.57
Just picked this Yukon up a few weeks ago. Dealer said they had the oil changed but I just don’t trust anyone else to change my oil. I’m particular about my maintenance so for my peace of mind, I went ahead and picked up the oil and filter today at Walmart and changed it. Hoping to get as many miles as possible on this bad boy before I have to replace any of the original drivetrain.
That about 1/4 of what a GM Stealership would charge you!
Tell me about it. They don’t touch our vehicles, not even my wife’s ‘21 Acadia. They gave us like 3 free oil changes when we bought it, and I told my wife when we walked out of there that it would never be back up there unless it needs warranty work. I do all of our maintenance and if there’s something I don’t have the tools or time to repair, I’ve got a real good buddy of mine who’s a fantastic mechanic.
2014 Jeep GC limited. 0W-20 Kirkland full synthetic with a Mobil 1 extended performance filter. I will run this oil for 5,000 miles and replace the oil again when it hits 10,000 miles. I will replace the filter at 10,000 miles. I used the mighty vac to vacuum out the old oil. I really don't worry about cracking the filter housing on the Jeep. These filters on top are so nice and easy to change. The old oil and filter still looked great but I like keeping my engines clean.
2021 Ford F150 5.0 V8
Odometer: 11,956
OCI: 4,789
Out: 7.75 qts dealer fill (likely Motorcraft synblend 5W30) and Motorcraft FL-500-S filter
In: 7.75 qts Mobil 1 Extended Performance 5w30 and Motorcraft FL-500-S filter
Total cost (Amazon): $51.50
I was not happy with the oil condition. Dark and smelly even though the OLM said 45% oil life remaining. We will see how Mobil 1 Extended Performance holds up at 5,000 miles. If it stays cleaner, I might extend to 7,500 interval. My concerns are to keep the cylinder deactivation passages clean and minimize timing chain wear.
Champion 3500/4000 genset. Out 5w30 super tech synthetic in 10w30 circle k syn-blend. Uncles 12 accord out Valvoline MaxLife 0w20 w/ service champ filter in Mobil 1 Advanced Fuel Economy 0w20 w/ Mobil 1 filter.
1994 Mercury Cougar
3.8 V6
Out: unknown oil, Motorcraft FL400S filter
In: Valvoline Advanced synthetic 5w30, Motorcraft FL400S filter
1998 Chevrolet S10
4.3 Vortec V6
Out: unknown oil, Napa ProSelect 21036 filter
In: Castrol GTX HM 10w40, AcDelco PF52E filter
2021 Ford Ecosport
Out: Factory fill
In: Castrol Magnatec 5w20
Fram XG3614
Easy oil change, didn't even jack it up. The filter is mounted vertically right in front of the oil pan. Probably the tightest factory drain plug I've ever dealt with.
The FoMoCo filter felt flimsy. When I tried to undo it by hand I was able to flex the filter walls. I wasn't able to do that on the Ultra. Plenty of sparkles in the drain pan but I don't allow myself to overanalyze on a first change. Got (3) 5 quart jugs of Castrol on sale for $50 on Amazon so I'm set for a while.
My DD 2020 Ford Fusion SE 1.5T FWD
15,076 on car
5,089 on oil
OUT: Napa 5W-20 Synthetic Blend (API SP), Motorcraft FL 910S filter
IN: Dealer service, Motorcraft 5W-20 Synthetic Blend, Motorcraft FL 910S filter.
Notes: at 5,xxx miles the oil was BLACK. The recommended service interval is 10,000.... really... on synthetic blend??? NO WAY!
Not for a car I plan on driving every day, and then giving to my oldest kid to drive in 7 ish years.
Unfortunately I was unable to collect a sample of the Napa syn blend from this change interval due to the dealer service.
2013 Tahoe
160,000 miles
Out: Carquest clearance 10W30, 0W40 mix
In: Mobil synthetic high mileage 5W30
Left the Fram ultra filter on
Tomorrow will be my moms 2015 Lincoln MKC 2.3 turbo with 121,000
Out: I can’t remember
In: Castrol Magnatec 5w30 and a fram ultra
2021 Silverado 1500 3.0L Diesel
9,996 miles
5,035 miles on oil
Out: 7qts ACDelco 0W-20 DexosD light duty diesel oil, ACDelco PF66 filter
In: Same
I was shocked to find this oil at the NAPA near me for $5/qt. One of the owners buddies has the same truck so he ordered a bunch. I also sent a sample to Blackstone.
2021 Subaru Outback
ODO: 14715 miles ( interval: 7289 )
out: 4.5 qt Valvoline Extended Protection 0w20 + Subaru ( Blue Fram ) Filter
in: 5 qt Dealer VRL0W20 + Subaru ( Blue Fram ) Filter
Note: Dealer Over-filled by ~ 0.5 qt.
Capacity = 4.5 qt. r.0: charged 6qts. Oil change and tire rotation was free
