In: 5qts of Liquimoly Leichtlauf High Tech 5W40, 0.75 qt of Castrol Edge 5W40, 0.25 qt of Supertech 5W30 high-mileage conventional, Liquimoly Ceratec, Mahle filter, new drain plug
It will be done...do one each time.I wouldn't mind seeing a used oil analysis after that OCI.
MoS2 is a dark grey color and shimmers - it will tint the oil a darker color. I thought 1 can of MoS2 was good for 1 change - why for 2? Does your vehicle have a v. low oil volume?2020 Mitsubishi Mirage
Out: Mobil 1 Advanced Fuel Economy 0w20
Fram TG7317
In: Mobil 1 Advanced Fuel Economy 0w20
Fram XG7317
I also added in 5oz of Liqui Moly Mos2. I've never used an oil additive before and I picked up a bottle for $8 that will do 2 oil changes. So what the heck right? The engine does seem ever so slightly smoother but it may just be placebo.
It is interesting how the oil is now tinted darker from the additive. Looks like it has a few thousands miles on it immediately after changing which is hard getting used to.
Have you noticed any actual MPG gains from using AFE in your mirage? I was thinking about trying it out in mine once I run out of my valvoline stash to see if it actually improves fuel economy of not.2020 Mitsubishi Mirage
Fram TG7317
Fram XG7317
The mirage holds 3.2 quarts of oil which ain't much but it's plenty for a 1.2l 3 cylinderMoS2 is a dark grey color and shimmers - it will tint the oil a darker color. I thought 1 can of MoS2 was good for 1 change - why for 2? Does your vehicle have a v. low oil volume?
Ah got it.Have you noticed any actual MPG gains from using AFE in your mirage? I was thinking about trying it out in mine once I run out of my valvoline stash to see if it actually improves fuel economy of not.
I've only ever used AFE in both our cars so i can't speak to any MPG improvements. I do too much in town stuff to really ever draw any conclusions for MPG changes. I sit at too many lights and deal with too much slow moving traffic.Have you noticed any actual MPG gains from using AFE in your mirage? I was thinking about trying it out in mine once I run out of my valvoline stash to see if it actually improves fuel economy of not.
