Post your latest oil change
2011 Ford Focus SE, 2.0L
Out: NAPA Synthetic 5W-20 .... NAPA Gold Oil Filter #1348
In: Valvoline conventional 5W-20 .... Hastings Oil Filter #LF655
Severe Service
** Added bottle of Gumout Regane High Mileage Fuel System Cleaner to fuel tank before this oil change
Also changed the following:
Engine Air Filter
Out: Motorcraft #FA1890
In: Hastings #AF1400
2012 Chevy Cruze 1.4T 55K on unit 5K oci
Out: 4 liters Quaker State Ultimate Durability 5w30 and Fram CH10246
In: 4 liters Quaker State Ultimate Durability 5w30 and AC Delco PF2257g
2016 Honda HR-V
6,409 miles, approx. 10 or 11 months on oil/filter (first oil change)
Out: Factory Fill/Factory Oil Filter
In: Quaker State Ultimate Durability 0W-20, Purolator Synthetic PSL14610
2007 Toyota Yaris. 142,2xxKM, about 9200KMs on oil and filter.
Out: Pennzoil Platinum 5w30, Napa Gold 1394.
In: Chevron Supreme 5w30, Fram TG 4386.
2012 Hyundai Elantra GLS, 1.8L
Out: NAPA Synthetic 5W-20 .... NAPA Gold Oil Filter #1334
In: Valvoline conventional 5w30 .... Hastings Oil Filter #LF565
Severe Service
Engine Air Filter
Out: Hastings #AF1511
In: Hastings #AF1511
Cabin Air Filter
Out: FRAM Fresh Breeze #CF10728
In: Hastings #AFC1447
160K 98 toyota corolla
out: mobile 5000
in: Valvoline synpower 5w30
filter: PurolatorONE Oil Filter
Is 5000k reasonable for valvoline synpower?
out: mobile 5000
5k miles is easy for any synthetic. I'd push it to atleast 6,500 or 7k
2006 Dodge Grand Caravan 3.3L 200822mi
Out: TA 5w30/CS 10w30 3 makeup qts CS 10w30 OCI 9334 time 56 days consumption approx 2350 mi/qt
In: Cam2 10w-40 synblend
FU XG 16 filter not changed.
'09 Subaru Forester, 83K car
Out: Ultra 5w30, D+ filter
In: Ultra 10w30, Mobil 1 filter
Not sure how long I ran the last fill, so I'll run this one only through October, when it'll get Ultra 5w30 and a K&N.
2008 Dodge Ram 2500 5.7 Hemi
O' Reillys Dexos Full Synthetic 5W30, Baldwin B329
drain plug 25 ft lbs
2012 Chevy 2500 6.0 Vortec
Smittys SuperSyn Dexos 5W30, Purolator ONE PL12222
drain plug 18 ft lbs
1st oil change on my 2016 157" wb 2wd F150 Lariat with the 2.7 EcoBoost. Purchased new late January 2017. Mileage was 4950 and the meter was showing 53% oil life remaining. No oil was added during the 4950 miles and the oil level was right where it was the day I picked it up. I used 6 quarts of Motorcraft 5w30 Synthetic Blend and a Motorcraft filter in the change. I've read where other F150 EcoBoost owners have found that their used oil smelled of gasoline. Mine smelled just like every other container of used oil I've ever been around.
No doubt this was the most unusual oil change I've ever done, with the filter in a canister up at the top of the engine and a plastic drain plug (going into a plastic oil pan) designed to be taken off by hand. Ford recommends waiting 15 minutes after shutting the engine off before even checking the oil level. I've found that waiting 30 minutes gets a more accurate reading. With that in mind I let the oil drain an hour before I buttoned things back up and refilled the crankcase. I ran the engine for a few minutes after the change and then let the engine sit off for 30 minutes before I checked the level. The recommended 6 qts put the level on the stick even with the top of the crosshatch on the stick.
I suspect that oil change facilities of every kind are hating this engine....if they, in fact, follow the recommended procedure. I've read reports that early on even Ford dealerships were screwing up and sending oil change customers out the door with overfilled crankcases due to not allowing enough drain time. In my mind, done correctly, a change on the 2.7 takes about an hour, give or take a few minutes.
2008 Chevy Impala 3.5L V6
Out: 4 qts MaxLife Blend 5w30, - Bosch Filter 3423
In: 4 qts MaxLife Blend 5w30 - Baldwin Filter on 5-3-17
Miles on vehicle: 109,844
Miles on oil: 7,218
Time on oil: 6 1/2 months
1 quart makeup oil used during OCI
- car use is more than 50% short trips. I'll post a used oil analysis on this change later this month.
2016 Jeep Grand Cherokee SRT 6.4L V8
Out: Pennzoil Ultra SRT 0w-40, MOPAR filter
In: Pennzoil Ultra SRT 0w-40, FRAM Ultra filter
Miles on oil: 5,000Km
Miles on vehicle: 17,158Km
Zero make-up oil added.
