Post your latest oil change
73 GMC one ton crew cab, 355 10.5:1 234/240 .050 cam, 1.6/1.5 rockers 116 LSA: out: 15w40 Duron CI-4+ from 2007, in Pet-Can supertest TO-4+ SAE 30 X-long Baldwin filter.
10 years of moving the truck around the yard, it was time to change the oil that smelled like gasoline.
Tomorrow the same on a 327 hottie in a 82 Chev monster truck, but it has only been sitting for 6 years or so.
2008 Generac 20KW Automatic Whole House Standby Generator (999cc) - Annual Change
1.9 Quarts of Amsoil Synthetic 4-Stroke Small Engine Oil (10W-30/SAE 30 Commercial Grade)
Generac OEM Filter
2008 Acura RDX w/ 110k
Out: Pennzoil Platinum 5w30, Fram Ultra XG 7317
In: Castrol EDGE Extended Performance 5w30, Fram Ultra XG 7317
The RDX is such an easy change. Always 5 qts out, 5 qts in, easy access to the filter. The SAABs always take more level-checking.
1983 Saab 900 GLE, 125.000km. OCI ~4700km.
out: cheap Mannol 10w-40 + Champion C165
in: Mobil 1 5w-50 peak life + Mann w712/80
Vehicle has a history of neglect by the previous (female) owners. Had lots of sludge when I bought it and required a head rebuilt and a new timing chain @ barely 108.000km. I am running very short OCIs to clean her up.
When I got out the oil filter, I found this nice thing on the baseplate (had not yet entered through the entrance holes). One side rough textured as shown in the picture, the other side smooth and shiny. Not sure whether carbon or varnish. It is semi-brittle - can be bend a bit before it breaks.
So far for "don't be afraid, there is no blocks of junk braking of and wandering through your engine, new oil will just gently dissolve the deposits..."
Have filled a sample for UOA and have saved the filter for a c&p.
2004 Toyota Solara SE
Out: Pennzoil Ultra Platinum 5W30
In: 1 qt Mobil Super 5000, 3.25 qts Quaker State Defy 10W30 and some leftover Mobil 1 0W40 VISOM based.
Oil filter will be used for another 6,000 miles
2004 Tacoma
Out: Pennzoil Platinum 5w30/OEM Toyota 90915-YZZD3 filter
In: Pennzoil Ultra 0W-40/OEM Toyota 90915-YZZD3 filter for another 7500 miles!
Friend's 2015 Hyundai Santa Fe with 2.0 turbo
Out: Pennzoil Platinum 5W30 and Wix 51334
In: Pennzoil Platinum 5W30 and Wix 51334
02 Grand caravan
In Pennzoil Conventional 5w30
Filter left in service
03 Neon
Out: Quaker State Conventional 5w30 and Wix
In: Valvoline 5w30 conventional and Fram ocod
92 Volvo 240
Out: Pennzoil Conventional 10w30 and Mann filter
In: Castrol 10w30 and Fram ocod
2007 BMW X5 4.8i
Out: 9qts Castrol EDGE 0W-40, Mann filter
In: 9qts Castrol EDGE 0W-40, Mann filter
5k OCI because oil from Walmart is cheap, BMW engine parts are not.
2011 Buick Regal w/ 2.4L engine
74,400 miles
4500 miles on the previous fill of Valvoline MaxLife 5w30
New: Buick dealer's Dexos oil (prob. Mobil 1?), 5w30, their filter, w/ tire rotation
OLM read 14%
2011 Town and Country. 55000 miles
Out
Pennzoil Platinum 5w30 Mopar filter
5000oci
In
Quaker State Ultimate Durability 5-30
Fram TG
Co workers - 2005 Chevy Silverado 1500 Ext Cab - 5.3L V8 - Auto
Miles on vehicle - 161,700
OLM - 0% - it's been flashing for a couple of weeks
OCI - 5 months and 8,853 miles
Out - 6 qts of Havoline Conv 10W30 and a Fram TG3506 filter
In - 6 qts of Chevron Supreme Conv 10W30 and a Fram PH3506 filter .
2010 Ford Fusion 2.5 in my sig - 230,449 miles on the Odo, 2864 on the oil and filter. Drained oil was put in by dealer following cylinder head overhaul/valve job.
Oil out ---- Motorcraft 5w20
Filter off - Motorcraft FL910s
Oil in ----- Valvoline Max-Life 5w30 (5qt) + Valvoline Next-Gen Max-Life 5w20 (0.5qt)
Filter on -- Bosch Distance+ D3422 (Which I found for $1 on the Wal-Mart clearance shelf)
2004 Ford Explorer 101K miles 9mo/5k miles severe service (yes, I know it could have gone farther
Out AMZ SS 5w30 and AMZ filter
In Pennzoil Ultra Platium 5w30 and Fram Ultra
1999 MB CLK320 139K miles
Doing short OCIs to slowly remove varnish and mild sludge from %$^&# PO.
Out AMZ 5W-40 and Mann Filter
In: tried to whittle down stash - 6qt LM Leichtlauf 5W-40 and 2.5qt Castrol 0W-40 and a Mahle Fleece filter
Should be able to leave this in longer - looking MUCH better inside VC.
2016 F150 5.0
Out-Mobil 1 Extended Performance 5w20, Motorcraft FL500s
In-Mobil 1 Extended Performance 5w20, Mobil 1 Extended Performance filter. (Rebate on oil and filter)
7500 miles on oil and filter
Will be going back to the Motorcraft filter on next change after cutting open and seeing how well it held up.
