Post your latest oil change
2008 Mercedes-Benz C300
Out: 8.5 quarts Mobil 1 0w40 / Mercedes 000 180 2609 Oil Filter
(Sucked out with Mityvac Plus)
In: 8.5 quarts Mobil 1 0w40 / Mann Labeled (OEM Same as Above) HU 718/5
4,038 Miles on the oil (1 Year).
Amazing to me how you can suck the oil out of these cars and have the oil filter right on top. I had to put the full 8.5 quarts in to make it 100 percent "MAX," so you can truly get almost every drop with this method on Mercedes vehicles.
Note, when dealer did my car it always came back in varying degrees of overfilled. They obviously aren't as good at sucking it all out! I may try to post an image of the used cartridge oil filter in the Oil Filter forum later in the week. The construction of these cartridges is superb (no idea on the filtering performance though).
Lancer Ralliart Sportback 2010 (turbo) 37k miles
*peace of mind change from Mobil Super 5k conventional.
to
Kendall GT1 semi synthetic 5W30
Champion filter PH2808
OCI 3750
2002 Ford Focus 87,255 miles
around 5,000 miles and one year on oil
out: amsoil 0w-20 sso and eao oil filter
in: same
2003 Mazda Tribute 3.0L V-6
Out: PYB 10W-30 and Fram PH2; 6500 miles on oil.
In: M1 AFE 0W-20 and an M1-210 filter.
- old oil sent out for UOA, will post soon.
*Sorry, last post I said wrong oil. (Habit)
2010 Lancer Ralliart
Valvoline Syn Power 5w30
Valvoline oil filter
Purolator classic air filter.
36800 miles
CHANGED TO A K&N PANEL FILTER.......
36800 miles
1998 Honda Civic 240k+ miles
3750mi / 1 yr OCI
New oil for the Winter. Using this vehicle more often again, so next OCI will probably be in 6mo.
In
G-Oil
Purolator Pureone filter
OUT
QS HM / Supertech 5w30 Mix + another qt of supertech along the way.
2002 Buick Century. 65K Miles. 5K OCI.
Mobil 1 5W30.
WIX 51040.
I had a K&N HP-1001 for the oil filer. One will go back in due to ease of replacement. The 1" nut is a big help.
Today I changed the oil in both vehicles so I dont have to mess with them during winter:
06 Focus: Out- Mobil Clean 5000 5w30 and Motorcraft FL-400s
In: PYB 5w20 and FL-400s
04: Highlander: Out: Chevron Supreme 5w30 and Puro Classic
In: QSUD 5w30 and Napa Gold
also, did a drain/fill on the Highlander trans. Out: 3qts Toyota T-IV
In: 1/2qt Toyota T-IV, 2 1/2qts Maxlife
Last Sunday...
07 Golf V R32 105000km
Out : Unil-Opal Opaljet 5W40 505.01 & Knecht filter 7500km on oil
In : Castrol Magnatec DPF 5W40 505.01 & same filter
Out:
Kendall GT1 blend 5w30
Champ filter
K&N panel air filter
In:
Valvoline SynPower synthetic 5w30
Valvoline VO-106 oil filter
Napa Gold air filter.
2009 Ford Fusion:Out Quaker State 5w20 dino and Motor Craft filter.In:Quaker State 5w20 dino with Motor Craft filter.2003 Dodge Neon:Out Quaker State 5w30 dino with Quaker State filter.:In Quaker State 5w30 dino and again Quaker State filter
