Interesting mix2.5 qts of 10w30 and 2 qts of 0w16.
Agree. I think the small opening is even much less common now than the large opening.It looks like a 1qt bottle. Some of those Mobil bottles have a wide opening (similar to most 5qt bottles in diameter). Much larger than classic/old school/HPL quart sized openings.
That's a lot of miles2007 Silverado 5.3 240,454k ( friend just bought ).
Out: Quick Lube Special / Ecoguard Filter.
In: Royal Purple 5w30 / Carquest Blue.
Thinking at that point - 240k is conversantThat's a lot of miles![]()
Does that mix/cocktail have a name?2011 Honda CR-V 140k miles
Out: Fram 0w20 Synthetic, Carquest Premium Filter
In: Mix of STP, Pennzoil, Castrol and Fram 0w20, 5w20 and 5w30 synthetics. Mostly STP 5w30 High Mileage synthetic.
Filter: STP 7317XL, unknown manufacturer, maybe PG? Made in China, silicone ADBV and O-ring, came sealed with cellophane.
View attachment 312498View attachment 312499
It's too bad they stopped making those basic Rangers in 2011. I liked the basic rear wheel drive, manual transmission models. Perfect third vehicle for a home owner to do home depot and garage dump runs.I changed the oil in my son's 2008 Ford Ranger 2.3 last week. The engine now has 255K with 10K OCIs, which is about once a year. Oil consumption was about half a pint of Mobil 1 High Mileage 5w30.
Out: Mobil 1 High Mileage 5w30
In: Mobil 1 High Mileage 5w30
Oil Filter: Fram Ultra 3614
They're still around and hold their value relatively wellIt's too bad they stopped making those basic Rangers in 2011. I liked the basic rear wheel drive, manual transmission models. Perfect third vehicle for a home owner to do home depot and garage dump runs.
My experience with owning various vehicles over the last 40 years is that I never noticed any difference whatsoever between different premium brand oils and even with budget priced oils. They all did their job during the oil change interval with no issues whatsoever.I've run Mobil 1 Extended Performance exclusively the entire 25k miles but just to try something new I tossed some Pennzoil Ultra Platinum in today just to see if I notice any difference compared to Mobil 1 Extended Performance.
12/21/2025
2021 Mazda CX-5 Grand Touring Reserve
2.5 Turbo
25,168 Miles
Pennzoil Ultra Platinum 5W30
Mazda 1WPY14302 Oil Filter
Votex Magnetic Drain Plug/Crush Washer
You will likely notice no difference at all, but please keep us posted.
I have some experience with Pennzoil Ultra and Pennzoil Ultra Platinum.Probably not but 2 oils I was curious on are Pennzoil Ultra Platinum and Valvoline Restore and Protect so decided to try one. I haven't used anything other than Mobil 1 in many years.
Not doing it at your own shop?I’m not ashamed to admit that even as I write this, I’m sitting in my wife’s car at a Valvoline
As The Critic knows,I used to own a Big O Tires store when I first joined BITOG. Since then I’ve sold the store and retired, and now I have a gravel driveway, and I’m too thick to fit under my vehicles, hence the quick lube.I’m not ashamed to admit that even as I write this, I’m sitting in my wife’s car at a Valvoline quick lube getting the second Valvoline Restore and Protect oil change.
