LOL, my brand loyalty is only in "name" only. I actually have used and really like Valvoline products in the past. I expect it will be the same with Valvoline Restore and Protect.That’s not a SOPUS product![]()
2017 4runner, 85k, 9 months 5k miles on oil.
Out: 3 qts of Castrol Edge 0w16 and 3.5 qts of Castrol Edge 10w30, Baldwin filter.
In: 3 qts of Castrol Edge 0w16 and 3.5 qts of Castrol Edge 10w30, Denso filter.
Also side rotated tires, changed cabin filter and greased drive shaft.
It's the oil control ring, spark plug #1 was the only one that had oil-coated threads and it runs the same as my 17 Accord.try a 5w30 in the accords. i have two that i have reduced oil burning to near zero on.
I'm curious about the mixing 2 different oil weights2011 Toyota Camry 2.5l.
105k, 13 months 5k on oil and filter.
Out and In: Castrol Edge 2 qts of 0w16 and 2.5 qts of 10w30, Toyota filter.
Now that's a unique oil change! What was the color of the 14 yr old oil coming out of the bottle? Did you shake the bottles? Was there sediment at the bottom?I think bitog will like this
2018 dodge durango 3.6l 118k
Out Mobil 1 High Mileage 5w30 with a fram ultra
In 5qts of circa 2010 Pennzoil euro l 5w30 and 1qt 5w40 with a fram FE
