Post your latest oil change
1987 Chevrolet Silverado R10
5.0 V8
Out: unknown oil, AcDelco PF1218 filter
In: Fram Conventional 10w30, Swepco 502 Oil Improver, AcDelco PF1218 filter
2005 Ford Mustang
4.0 V6
Out: unknown oil, unknown white can filter (sticker missing)
In: Fram Conventional 10w30, Swepco 502 Oil Improver, Motorcraft FL820S filter
VW Atlas 40,000 miles:
Oit: Motul X-Clean+ 0W30 EFE
IN:
Motul X-Clean+ 5W30.
OE filter in both cases.
Out: M1 EP High Mileage 5W-30
In: M1 EP 5W-30
Oil Filter
Out: TRD Cartridge PTR43-00082
In: Royal Purple Cartridge Extended Life 20-967
Miles: 2,957
Last change August 2023
I found what is now truly the last jug of M1 EP in the back of my "stash" cabinet, so the next change will effect the move to HPL.
2006 Chevrolet Silverado 1500 Extended Cab 4x4. 5.3 L33 H.O.
Oil: Pennzoil Full Synthetic High Mileage 5w30
Filter: Purolator L25288
This was following a flush with clean 5w20 Supertech Full Synthetic oil and a Qt. of MotorMedic engine flush with a clean filter, run for 5 minutes and drain oil and change filter. This was a used purchase and unknown engine history. The flush did clean a bit of sludge. I do have plans to pull the pan, clean, replace oil pickup o-ring and install improve oil pickup clamp.
Still working through my stash of oil that's older than myself, I'm almost done (I'm 22 btw).
My 2014 Pathfinder.
Out: 5qt API SJ Quaker State Conventional 10w30, 1 bottle 1999-formula STP Treatment, Fram TG6607
In: 5qt API SJ Quaker State Conventional 10w30, 1 bottle 1999-formula STP Treatment, K&N HP-1010
I'm sending out some of what I drained for a UOA and TBN, I'm curious to see how this old stuff held up.
2021 Kia Seltos - Out : M1 5W30 EP with Fram Ultra #9688 oil filter, 5K mile / 6 month OCI (I run two OCI ‘s with the same Fram Ultra) . In : Same as above . *The new M1 5W30 EP D1 / Gen 3 synthetic oil runs smooth and quiet in both this Kia Seltos 2.0L PFI engine as well as my 2017 Hyundai Sonata 2.4L GDI engine , so I’ll keep using it (as long as under $30 from WM) .
