Post Your Latest (Motorcycle) Oil Change!
Originally Posted By: blupupher
Those don't have a filter, right?
That's correct. Plus - having a CVT (no wet clutch), I can use any oil I choose.
20-oz of oil, I can get 3 oc's from 2-qts. lol
Just drain and refill.
Does the CVT share the same oil, or is it separate?
CVT is basically a centrifugal clutch that opens up (with rpm's) to vary the speed range.
No oil needed.
The only other oil is regular 80-90 gear oil in the rear end.
Bel-Rey Ester Synthetic Blend Thumper Oil, 15W-50
And a K-N #138 'cuz got a great deal on Amazon for 3 of them for like $4 each.
Engine and shifting just great on this stuff.
1993 GTS1000
out Repsol 10W40 + Sunwa filter (previous owner's choice)
in Motul 5100 10W40 + Champion filter
2017 KTM 1290 Super Duke R
3400 miles/11 months OCI
Out Motorex Power Synt 10w50 & HiFlo Filtro filter
In Motorex Power Synt 10w50 & HiFlo Filtro filter
2006 Yamaha FJR1300
3000 miles/9 months OCI
Out Mobil Delvac 15w40 + Mobil 1 15w50 & Bosch filter
In Mobil Delvac 15w40 + Mobil 1 15w50 & Bosch filter
Next time the Yamaha will likely get more of the same (working down a big stash) while I may try something different in the Super Duke (Castrol Power 1?).
2000 Kawasaki Vulcan 800 Classic
Removed Purolator L14612 filter and Rotella 15w40
Installed Supertech ST6607 and Mobil Delvac 15w40 that I got cheap from a walmart clearance
I was not happy with my ST6607.
i'm not really worried, i don't put a lot of miles on my bikes, and change the oil yearly, next year i'll cut it apart and check it out, i think i might have one or 2 more of these, i can't remember
otherwise i mainly use quakerstate filters in the same size, but i also have some defense 6607's as well, and some blue bosch filters
Moto: 2007 Yamaha FZ1
Previous Fill: Redline 10W40 and HiFlo 204RC oil filter
OCI Duration: App. 1200 miles- including 5 track days
Current Fill: Maxima Extra 4 15W50 and Yamaha OEM filter
did early oil changes on both the scoot & the moto due to more frequent idling & stop-n-go in traffic (paving, sewer pipe replacements, oil & natural gas pipeline construction zones); kept oil filters in place & used 'frankenbrew' of 15w40's (traveller, Valvoline conventional) & leftover frankenbrew (10w-40 & 15w40 & a touch of 10w30 hdeo); think I added Amsoil OE 15w40 a while back to augment the frankenbrew...
got less than a gallon left...might thin it out a bit with some 10w-40 m/c oil to do oil changes in the fall for winter storage
1)1993 Honda CB 400 SF. OUT: 2,9 lt MOTUL 5100+Honda oil filter.IN: The same, 3000 kms OCI 2)1999 Vespa px 200 fd: OUT 250cc of unknown gearbox oil from my vespa workshop. IN : 250 cc BP 80W90 GL4 Gear oil, 3000 kms OCI.
2018 Kawasaki Z650
OCI: 500 miles (first oil change)
Out: Factory fill & factory oil filter
In: Motul 5100 10w40 & OEM oil filter.
It took slightly more than 2 quarts. I still have more than 2 quarts of 5100 on hand (got it for cheap), but eventually will switch to Rotella after using this jug
2011 BMW R1200R 50,082 miles
out: 5028 miles on Castrol Syn 5W-50
in: Valvoline VR-1 Syn 2 qts each, 10w30 & 20W-50
Mahle Oil Filter OC 306
'14 v star 250... @ 3750 miles; out...mostly 15w40 with some 10w-40 frankenbrew & hiflo filtro hf145 filter; @ 1000 miles on oil & @ 2000 miles on filter; in...smitty's super s multi-flo 10w-40 & leftover frankenbrew & fram ch6004 filter; also cleaned & oiled foam air filter, applied chain wax, and tensioned chain; will replace factory spark plugs sometime this week
this current oil change will cover riding & storage til temps warm up in spring...
2014 Triumph Tiger 800 XC
out: 1/2 quart Maxima Extra4 Maxum4 10w60, balance Rotella T5 15W40
Miles on oil: roughly 3k (lost trip odometer; finding new tracking method.)
Time span: late April to late September
In: 1/2 quart Maxima Extra4 Maxum4 10w60, 1 quart Valvoline Synthetic Motorcycle Oil 20w50, balance Valvoline Synthetic Motorcycle Oil 10w40
Just curious, why the mixing?
