Post Your Latest (Motorcycle) Oil Change!
Yeah I saw the T5 but wonder why Shell doesn't say it meets the specs for MA/MA2. The T4 and T6 are not tested or certified for the JASO MA specs -- none of the Rotellas are -- but at least Shell says the T4 and T6 meet the performance specs. So that's why I haven't used T5. Glad you had good experience with it though :)
The T6 in 15w-40 meets JASO MA / MA2 specs. I currently use it in my Victory 106 with great results. I'll be posting a UOA later.
t6-sae-15w-40.pdf (shell.com)
2014 BMW R1200R
Out: whatever the BMW dealership where I bought the bike used
In: 1 gallon Castrol ActEvo 20w-50, BMW OEM oil filter
I am using both Rotella T4 15w40 and Rotella T6 15w40 in my dirt bikes because the label says it meets the requirements of JASO MA/MA2.
The Rotella T5 label does not say the same.
I have an honest question out of curiosity... How many years were guys using T4 back in the day before it had a label?
Myself, zero. Before I discovered the JASO MA/MA2 language on the Rotella label, I used only Maxima SynBlend4 10w40 or Valvoline 4 stroke 10w40. I am not in the habit of experimenting with oils, but at the same time I knew there must be a better option than $8/quart motorcycle oil for us casual riders, so I kept looking and eventually found Rotella.
Just like the T5, other diesel oils and Castrol GTX, many people currently use them even if it doesn’t show JASO MA.
Recently acquired - new to me .
2002 Harley Davidson Sportster 883 XLH Hugger
Miles on bike : 16,295 miles
OCI : Unknown
Out - Unknown oil and Wix 51215 filter
In - 3 qts Mystik JT-8 15W-50 and Motorcraft FL-400S filter
2010 Harley CVO Streetglide with 31,500 miles
Out: Valvoline Vr1 20w50 conventional
In: same w a Harley filter
Primary: out Harley Formula Plus 20w50 conventional
In: Harley Syn3 20w50 synthetic, because I had 2 qts on the shelf. No problems with the Formula Plus.
Transmission: Didn’t change. I change the Redline Shockproof every other OCi.
2003 Honda XR400R
Out: Rotella T4-15w40 and Rotella T6-15w40, half & half. Total 1.8 quarts
In: same as "Out"
This drain had about 400 miles of mixed fire roads and hard single track off-road riding. Oil was dark but not nasty, still felt smooth and very slippery. Hardly any ferrous goop on the magnetic drain plugs (one on frame reservoir and one on engine case).
Checked the spark plug and cleaned the air filter while I was at it :D
2021 Kawasaki KLX300SM 602 miles
Out: Rotella T4 15w40, OEM oil filter, 450 miles
In: Motul 7100 10w40, OEM oil filter
How are you liking that KLX? There’s a thread just below this one about the new KLX, just curious what your first impressions are. https://bobistheoilguy.com/forums/threads/2021-kawasaki-klx300sm.340818/
I really love the bike. It is smooth, the brakes are excellent, the clutch is easy to work, the grips are nice, has a nice helmet lock from the factory, sips gas, and is fun to ride around for hours on end. Only mod I made was to cut the rear fender down. First bike I ever owned that I didn't immediately start changing stuff, it is pretty well sorted straight from the factory.
Great picture you took of the bike in the other thread, it’s a good looking one!
2000 Honda Shadow 1100 ACE - drained out Rotella 15w40, removed non-ecore Supertech filter
Installed new e-core super tech filter, and refilled with 15w40 Rotella, hopefully this is the last oil change I do on this bike as my dad is trying to sell it.
2008 Yamaha Royalstar Venture 1300 - drained out Amalie 20w50 and Fram 6017a
Installed Supertech ecore oil filter and put in a 50/50 mix of Rotella 15w40 T4 and 15w40 T6
2020 Benelli TNT 135
Miles: 75
Oil:
Out: OEM Chinese oil
In: 32oz Valvoline 10w40 petroleum m/c oil
5oz Mystic JT8 15w50 syn blend
Filter:
Out: OEM Chinese filter
In: K&N 112 filter
2016 Yamaha WR450F, approx 130 hours run time
Oil capacity is 700cc (24 fl oz)
8.5 hours on this service interval
Drained: Rotella 15w40 T4/T6 blend (50/50)
Added: same
Checked oil screen, perfectly clean / no debris or shavings, installed new O-ring
Oil filter replaced every 3-4 oil changes, not done this time.
2011 FLHP
miles approx 3500
Oil mixture of VR1 SYN & VR1 dino
filter Wix 57148
primary Rotella T4 15w-40 changed every time with engine oil
trans Mobile 1 syn 90-140 drained every other engine oil change
