Post your latest HDEO change
2008 Silverado 2500 Duramax 6.6
Odo: 196510Km about 122105Miles
First oilchange for me. Just got the truck and notice a low hot oil pressure so look at the recepies from the latest oilchange done at 121357 Miles and see that they used 5w30 :(
Out LiquiMoly Top Tec 4200 NG 5w30 AC Delco PF 2232
In Shell Rimula R4 L 15w40 AC Delco PF 2232
2022 Ram 2500 CTD
Early OCI getting ready for a 5k mile trip next week.
Out: VPBEx 5-40 and Baldwin BT7349 filter
In: VPBEx 5-40 and FleetGuard LF 16035
Also changed both fuel filters. Changed air filter last week so it should be ready to go.
11.5 quarts puts it right on the full mark
Is this generator in New Jersey?
Nope. USVI. In NJ, barring some kind of beyond significant disaster where fuel will become the limiting factor anyway, there’s little to no reason for a generator, certainly not anything bigger than a 15A circuit if you’ve set up your situation right.
2012 Ram 2500 6.7L with 204,578 miles.
6978 miles/225hrs. on this change interval.
Out: DELO XSP Full Syn. 15w40 & Donaldson P551018
In: Valvoline PBE 5w40 & Fleetguard LF9028
Do you run the 9028 for multiple OCI’s or just for 1 extended OCI ? I know your truck runs a little cleaner in the oil department compared to mine still under warranty.
Just one interval, around 10k typically. After doing a few C&P on here based on the construction it could go way further.
I bought four of these from someone who traded in their Ram on a Ford, couldn't pass up the deal. I doubt I would ever pay retail for them when the Dual Flow Baldwin BD7317 can be found for around $20 withe same micron rating.
Link: https://www.circlecsupply.com/baldwin-bd7317-dual-flow-lube-spin-on.html
I have run the Baldwin filter before.
Ok, while not an oil change yet.... I found a mangers special for oil at a local gas station. It was a year old so they were moving stock. 36 bucks snagged me 12 litres of group 4 based 0w40. This is the same Co-op DMO that I have been using for years. With filter, the next change on my 2017 6.7 Cummins will cost 50$.
Now, gents, I am not sure how I feel about this. Using a 40 weight oil? Its bad enough my current 6.7 brew is partially 40 weight....
