That's hot! ;-)2021 Jeep Wrangler transfer case and differentials with Amsoil!
Any issues with the Mobil 1 ATF for transfer case use - seems like a bargain at the right viscosity and Grp4/Grp3 mixRam 2500 NV273 Transfer Case Fluid change.
38,944 miles on this change.
Out: two quarts Mobil 1 Synthetic ATF
In: two quarts Redline D4 ATF
No, everything seemed fine. I’d run it again.Any issues with the Mobil 1 ATF for transfer case use - seems like a bargain at the right viscosity and Grp4/Grp3 mix
Thanks - I first saw the VI - and that sent me right to the SDS.No, everything seemed fine. I’d run it again.
Got to looking and this Mobil 1 ATF is becoming very hard to find - but what was interesting is that the replacement has gone Grp3 only - yet carries a long list of recommendations much like Valvoline does …No, everything seemed fine. I’d run it again.
I had a hard time finding it on the shelf during my last change as well.Got to looking and this Mobil 1 ATF is becoming very hard to find - but what was interesting is that the replacement has gone Grp3 only - yet carries a long list of recommendations much like Valvoline does …
(Guessing some wiz-bang add packs) …
However, looking for 3 year runs in TC’s - got a six pack of the Grp3/Grp4 Mobil 1MV-ATF …
Did it take more than 6 quarts?2021 Toyota Tundra 5.7L DCLB 4x4
Out: Factory fill w/ 28,259mi on fill/unit.
In: Ravenol DGL 75W-85 LS.
Oops, forgot the new generation started in 22. It sometimes takes more if filled on the ground vs. stands.No but surprisingly it took 3.2L (3.4qt) to fill the rear end despite the owners manual saying 3.6-3.75L and Amsoil's site saying 4.6L (8 pints).
May have to drive it around and check it again.
