post your latest differential fluid change
2005 Mustang GT 3.55 ratio and 8.8 factory gears
86k miles on car
out @~45k Redline 75-140
In Supertech 75-140 synthetic
2010 Subaru Outback @ 14,2XX miles:
out - factory fill
in - Eneos 75W-90
@ 32,600 miles
out - Eneos 75W-90
in - Eneos 75W-90.
1999 Jeep Wrangler Sahara 109,712 miles:
Out(front/rear)- Mobil 1 75W-90
In(front/rear)- Mobil 1 75W-90
2002 Chev 2500HD, 58,000 miles. Mobil 1, 75-90. Third change--
First change was when new after 500 miles. This change seems very early since the fluid only had about 25,000 miles on it. I was getting chatter on tight turns. I was told the fluid needed to be changed, but the chattering continues on tight turns
no improvement
2007 Lincoln Mark LT, 50k miles. First change of front and rear differential hand transfer case. Fluid was Motorcraft syn. for front and rear plus friction modifier due to limited slip. Transfer case was Motorcraft transfer case fluid.
Land Rover Defender.
rear diff, Salisbury 8HA (metric Dana 60)
Fluid, Castrol SAF-XA 80W-140
front diff, Rover.
Fluid, Castrol (Australian) Syntrax 75W-90
Nissan Patrol GU ute.
Rear diff, Nissan H260.
fluid, Castrol SAF-XA 80W-140.
can't recall what's in the front diff.
2005 F150
OUT: unknown, it has been changed from factory at least once judging by the gray rtv on the covers and the remenants of the previous orange. I havent changed it since I bought the truck 4 years ago with 70,000 miles.
IN: Royal Purple 75w140 and 7oz of friction modifier additive
2004 F-150 5.4 3V
60k miles - Assuming original factory fill
Front Diff - Lucas Synthetic 75/90
Rear Diff - PML Differential Cover Installed
Mobil 1 75/90 + Friction Modifier
Originally Posted By: SXE10
Toyota Altezza RS200-Z - OE Torsen LSD 4.100
Out: I can only assume OE fill
In: Castrol SAF-XA 80w40 fully synthetic (I really like this stuff, torsen lsd hooks up much quicker)
I'm really surprised, I would've thought the friction modifier in SAF-XA (Sturaco 7098) would work against the the Torsen biasing quickly.
2006 Toyota Tacoma, 55.5K miles
Out: Factory fluid
In: AMSoil 75w-90 Full Synthetic, 9.2 pints/1.15 gallons.
