Can't you grind one side of the head flat to make it squeak by?Hub needs to be removed on some Honda’s to replace the studs.
"Grind me up a pound" fix for a bad design.
Something like this...
I’ve always been curious about Bendix. Never used their products, but that would probably be my next choice if I weren’t into Hella-Pagid stuff right now.Not done it yet. But I saw the toyota front brake pads to be at 2,5 mm when doing 5-tire rotation 2 weeks ago. Gonna order Bendix pads soon. I've been using Bendix brand since forever on all my vehicles.
Bendix pads are similar to Duralast Gold, BrakeBest Select/Import Direct and Carquest Blue/Platinum. MAT Roulunds India makes them. And they supply the parts store programs. Volvo also uses MAT as a supplier(Dan-Blok has been a long-time Volvo and Saab supplier and a aftermarket choice for European cars), Mercedes Star Parts pads are also made by MAT.I’ve always been curious about Bendix. Never used their products, but that would probably be my next choice if I weren’t into Hella-Pagid stuff right now.
Curious - why not try to buy those pads from a different source if they’re made by Baofeng, to avoid the Autozone markup?2017 Prius
Off - OEM Toyota pads and rotors
On - Duralast Gold pads, made in China by Baofeng Brake and Bendix PriorityOne Rotors from Amazon, also Chinesium.
I originally wanted the Indian-made pads. These were going on a taxi, so having the lifetime “warranty” would be nice.Curious - why not try to buy those pads from a different source if they’re made by Baofeng, to avoid the Autozone markup?
How bad was the job? I am not so good with drum brakes and my 01 Tundra will be due some day...2002 Toyota Tundra
Out = Factory Shoes
In = OEM Shoes + Turned Factory Drums
These are pictures of the original factory shoes.
Always Zimmerman's and OE pads on our MBs, BMWs, and the totalled VW. Tried others and they just don't bite the same.12 GTI I recently purchased had a pulsation under braking at highway speeds. Got new front brakes
OE/Dealer pads and Zimmerman rotors
I also like Textar stuff as far as bite but yes OE pads always preferredAlways Zimmerman's and OE pads on our MBs, BMWs, and the totalled VW. Tried others and they just don't bite the same.
Textar makes pads for Mercedes and BMW as does Pagid and someone else I forget.I also like Textar stuff as far as bite but yes OE pads always preferred
