mercury quicksilver 5 gal at 40/1 for my lawn biz . great stuff
Several I've tried recently:What have you mixed lately?
What are your observations with the Lubrication Engineers 8104 oil, compared to other oils you've used? Have you done any engine teardowns or just looked at the piston/cylinder after running it awhile? Curious to know if it leaves a decent oil film behind, and if piston rings stay free and clean etc.I presently have a 5 gallon container of 87 octane E-0 mixed at a 40:1 ratio using Lubrication Engineers 8104 oil. I run this in my leaf blower and string trimmer.
I do a much smaller mix using 87 octane E-0 fuel at a 32:1 ratio using Schaeffer's 706 TC-W3 for my Lawnboy.
I recently removed the head of the mower and noticed brown deposits that appeared to be remnants of the low-ash oil that I had been using. After this revelation I started using the recommended TC-W3 oils.
I don't care for the 8104. It's only average at best. One strange thing to note is that it will completely clog a fuel filter with some sort of clear jelly which seems to be in the mixture. I have tested this twice and gotten the exact same results. (filter used for testing is a NAPA Gold 3011 12 micron in-line cellulose filter)What are your observations with the Lubrication Engineers 8104 oil, compared to other oils you've used? Have you done any engine teardowns or just looked at the piston/cylinder after running it awhile? Curious to know if it leaves a decent oil film behind, and if piston rings stay free and clean etc.
I have been noticing black crumbly deposits on the plug of my lawn boy using Schaeffer's 7000 tcw3 i didn't have that before using supertech universal 2 cycle oil from walmart. The Schaeffer's oil has a bad odor as well.I don't care for the 8104. It's only average at best. One strange thing to note is that it will completely clog a fuel filter with some sort of clear jelly which seems to be in the mixture. I have tested this twice and gotten the exact same results. (filter used for testing is a NAPA Gold 3011 12 micron in-line cellulose filter)
According to some test protocols, a low-ash oil with a high calcium content can agglomerate in the presence of high moisture and lead to filter plugging. As an example, the NMMA TC-W3 test protocol allows for only 20% filter plugging for certification caused by this phenomenon. The 8104 fails this requirement miserably.
The oil leaves a dirty wash pattern on the piston dome but I have not noticed any signs of ring sticking. The wetting ability/residual coating of the oil is not nearly as good as oils such as Red Armor, Honda HP2, or even Opti-2 at lean mix ratios. Exhaust port cleanliness is only average and compares to the JASO FB rated Stihl HP Ultra. In my experiences, the only oils that have ever caused ring sticking in my OPE have been castor bean based products such as Blendzall green label racing castor and Klotz BeNol.
I will not purchase 8104 in the future because there are so many other superior lubricants readily available and at a much reduced cost. My local LE distributor/representative is also not a good person to do business with and therefore gives me no desire to consider their product.
This is the same as what use. So far I like it and the machines are running great with it.Two gallons of ethanol free 90 octane fuel mixed at 40:1 with Echo Red Armor.
L8R,
Matt
