Post your last blend
Last blend I used was Rotella SAE 30 SM and Quaker State Conventional SAE 30 from 2015 and some DELO CLE 10w30 CK4/SN
UOA coming soon
I notice fellow “mix not blend” Nazi is taking the day off. You know who you are
Latest Is 2 qts MC 15w40, 1qt Valvoline MaxLife 10w30, and 1qt of Pennzoil Platinum 5w-20 going into the 92 Accord. Will be doing a VOA then UOA at 5k for that one. Gotta get rid of the scraps.
Can I offer up a bit of advice if you want really to play the engine oil blending game...
First of all, I'd say don't bother with blending stuff that is nominally the same. If I look at the PQIA numbers for say conventional US GF-5 5W30s, I see a whole lot of oils that are 'more similar' than they are 'more different' (they also tend to be uniformly bad!). There is little to be gained from mixing similar oils.
Second, it's a truism in the additive industry that the most important bit of any additive is The First Bit. For example, if typically an engine oil contains 1.0% ZDDP, the first 0.1% of ZDDP you add to the oil will give a far bigger bump in oil performance that the last 0.1%. So part of the trick to blending oils is to find two oils which are both overly rich is one component or one property and blend these together to get something that may be better than the two individual oils.
For example, some synthetic Japanese oils are IMO overly rich in Moly (1000 ppm Mo isn't that uncommon). If for example, you were to add at 20% of this to say Citgo's Moly-free 10W mono-grade CF/CF-2 HDDO (actually a 10W16), the 10W is going to get a big kick in wear and oxidation performance from the Moly you add from the Japanese oil. However, whilst the 10W might have a decent content of ZDDP & Detergent, it might be somewhat deficient in Ashless Dispersant for a PCMO. In which case you might want to add say 20% of a modern CK-4 10W30 HDDO oil specifically because it will be loaded up to the gunnels with Ashless. If you really want to get creative, and TBN is the thing that floats your boat, then maybe blend in some Marine oil (no pun intended) because Marine oils tend to contain shed loads of over-based detergent relative to everything else they contain. Obviously you need to think hard about what objectives you're chasing and why but blending things that are 'different' is generally better than blending stuff that is the same.
Happy blending BITOG'ers!
Urban Dictionary: Enabler - Supports another's bad habits
That's what I've always meant by "linearity" in response...the behaviour is non linear...then the nett effect has to be additive to get you back to baseline.
Back in the day when unleaded was new in Oz, and we still had full leaded, a 50:50 brew of 98RON unleaded and 98RON super (leaded) was basically 100RON.
That's what I ran in my Torana (Slopeback Vauxhaul Viva, with 3000cc 6 cylinder, and I had triple 1-3/4 S.U. carbs amongst other things.
20L super (leaded 98RON)
20L Premium ULP (98 RON, and back in the day a LOT of bezene).
4 litres metho (methylated spirits)
250ml Acetone (or MEK).
2 boxes of mothballs
That was my "hi po" brew...only brew that would stop it running for 10-15 secs after turning it off.
Yep, that is what I ran all the time in my 11.5 : 1 compression motorcycles.
Originally Posted By: userfriendly
To avoid confusion, in NA we use RON+MON/2.
Not trying to start a fight, but is that
RON + MON/2
Or
(RON+MON)/2
I assume the second.
yep, the average.
Referred to as the Anti-knock index (knock having some wild threads lately). Was supposed to average out the "knock sensitivity" difference in fuels measured by the two different methods.
That was the edit after I read asleepz's post. Just incase he was referring to me.
Nope! Shannow gets all the credit for that one.
Originally Posted By: Ducked
Picky, picky. I knew what he meant, and I bet y'all did too.
For my sins, I am required to help high school students with their maths and science homework.
Working with teenagers, it's now obvious to me that brackets in mathematics and units in physics and chemistry are considered completely optional.
The look of disappointment on their faces when they get an exam back, with the correct answers but marks lost for incorrect working and missing units, is soothed by my serene smile, and the comforting words "I told you so".
Yeah, I picked up on that straight away.
No bonus marks for interpretation, intrinsic or artistic impression from those who see science 'n math as an art form.
