Can I offer up a bit of advice if you want really to play the engine oil blending game...
First of all, I'd say don't bother with blending stuff that is nominally the same. If I look at the PQIA numbers for say conventional US GF-5 5W30s, I see a whole lot of oils that are 'more similar' than they are 'more different' (they also tend to be uniformly bad!). There is little to be gained from mixing similar oils.
Second, it's a truism in the additive industry that the most important bit of any additive is The First Bit. For example, if typically an engine oil contains 1.0% ZDDP, the first 0.1% of ZDDP you add to the oil will give a far bigger bump in oil performance that the last 0.1%. So part of the trick to blending oils is to find two oils which are both overly rich is one component or one property and blend these together to get something that may be better than the two individual oils.
For example, some synthetic Japanese oils are IMO overly rich in Moly (1000 ppm Mo isn't that uncommon). If for example, you were to add at 20% of this to say Citgo's Moly-free 10W mono-grade CF/CF-2 HDDO (actually a 10W16), the 10W is going to get a big kick in wear and oxidation performance from the Moly you add from the Japanese oil. However, whilst the 10W might have a decent content of ZDDP & Detergent, it might be somewhat deficient in Ashless Dispersant for a PCMO. In which case you might want to add say 20% of a modern CK-4 10W30 HDDO oil specifically because it will be loaded up to the gunnels with Ashless. If you really want to get creative, and TBN is the thing that floats your boat, then maybe blend in some Marine oil (no pun intended) because Marine oils tend to contain shed loads of over-based detergent relative to everything else they contain. Obviously you need to think hard about what objectives you're chasing and why but blending things that are 'different' is generally better than blending stuff that is the same.
Happy blending BITOG'ers!
