Originally Posted By: JCCADILLACMOBILE
Originally Posted By: tig1
A friend bought a Ford that had oil abuse and ruined the engine in 50 miles after he bought it, as it was sludged like yours. After the pan was pulled there was an inch of sludge that blocked the oil pump pick up.
My advise is to have the pan removed before driving it any more.
My
Folks.... I cant help but think that IF an Engine was Sludged like that one (That pic was BAD, Folks!) That the following two things would be true:
1) That Even with all that "Sludge," AS LONG AS IT (The Sludge) WASNT ADDED TO (Using Good Quality Oil like a MaxLife HM Synthetic Blend, that Cleans AND protects against FURTHER Sludge Build-up) That the Engine would be OK, as i cant see if Sludge actually REALLY Affects Engine operation, except in maybe some Extreme Circumstances, if the impression i get when reading about Sludge: Its there, but so what...
2) IF Cleaning was desired, at least SOME would be.. that applications of MMO and SeaFoam for that last 100 miles before the OCI would GREATLY help Clean UNIFORMLY ... and let Nice, DIRTY Oil be Drained from Drain Hole and Filter.. Likely WITHOUT "Sludge Chunks."
It seems "Uniform Cleaning" is Key.. Taking it all out the VC galleys maybe made it Grenade itself (As Pan stories tell..) .. and actually seema good reason to Clean SOME Sludge GRADUALLY with MMO for 1000 miles before an OCI (Assume 3000 mile OCI i guess) and SeaFoam 100 Miles before OCI. then New Oil and Filter.
Yes? No? There are just my Insights..
For the record: My Jaguar's Oil was MORE THAN A YEAR Oid, and had LOW Oil Pressure (40 when drivng down the Road) BEFORE it was changed... so that makes me think I have Sludge.. but i have a Strategy to deal (Good Oil, MMO, SeaFoam, maybe once more, it seems to run OK I dont want to mess with my Engine TOO Much if its ok) .. but that Old Oil maybe has Sludged up many many things.)
... and this makes me add that "Sludge may not be as bad as they say"... Maybe it is, i THOUGHT it was, but upon Truly thinking about it.. is it really?
Id clean SOME, but it seems true that if you mess with an Engine too much...
Sad thing is, it would have probably run forever if left alone, now she will die on me in a couple of weeks
