We started our senior design for mechanical engineering and looking into some thoughts/ideas... I plan to talk with the professors soon about them (one is an advanced bearing analysis guy, so he would probably know for sure... But I thought I would self-moderate myself if the idea is too wacky!).
I have three automotive related ideas that will be thrown into our group "pool" and later pick the idea the professors and us like best. I just wondered if my ideas have any chance of working, if any of you have input.
First,
I was thinking of making a magnetic braking system to replace the rear disk/drums brakes... Replace the rotor with a copper alloy type rotor and the brake piston assembly would push rare earth magnets over the fin, causing braking force. Magnets cannot stop the car, so front brakes would still be required. This would reduce wear/tear and be maintenance free other than the fluid (theoretically). Would work much like magnetic braking systems on many amusement park rides which use permanent magnets on the ride car and the fins on the track. Completely power free. The main challenge would be designing the caliper system to fit inside the wheel.
Secondly,
Doing either magnetic or pneumatic bearings to replace the ball bearings in the wheels. Air bearings I have seen used in CT medical machines and it was fascinating how the rotors just float with basically no friction. You can spin the 1,000lb rotor on Friday and come back Monday and it still was moving. Was really cool. Wondering if we could do this somehow with car bearings to reduce friction and improve MPG and all that. Or if its really not even worth going for... Same thing with magnetic... Sort of like mag-lev trains and such. If that would even be possible.
Other ideas thrown around (non automotive related) include sanitation of escalator handrails using UV light or cleansers/heater system... Would be able to be retrofitted on existing equipment without replacing entire thing... Sort of a medical/health thing for malls and busy places when people want cleaner things to touch.
Comments/suggestions appreciated! Just going through some ideas for now.
Thanks!
First,
Secondly,
Thanks!
