Originally Posted By: MolaKule
Boric acid can be pumped in to further moderate the core if necessary, depending on the design and support systems.
This was announced.
Quote:
20:43 - TEPCO plans to fill the leaking reactor with sea water to cool it and reduce pressure in the unit, Edano says.
"The nuclear reactor is surrounded by a steel reactor container, which is then surrounded by a concrete building," Edano says. "The concrete building collapsed. We found out that the reactor container inside didn't explode."
"We've confirmed that the reactor container was not damaged. The explosion didn't occur inside the reactor container. As such there was no large amount of radiation leakage outside," he adds.
"At this point, there has been no major change to the level of radiation leakage outside (from before and after the explosion), so we'd like everyone to respond calmly."
"We've decided to fill the reactor container with sea water. Trade Minister Kaieda has instructed us to do so. By doing this, we will use boric acid to prevent criticality."
Edano says it will take about five to 10 hours to fill the reactor core with sea water and around 10 days to complete the process. He says due to the falling cooling-water level, hydrogen was generated and leaked into a space between the building and the container. It mixed with oxygen and exploded.
http://www.reuters.com/article/2011/03/13/us-japan-quake-timeline-idUSTRE72C2DH20110313?pageNumber=2
