Possible bad coil on Husky 150bt
Just want to cconfirm the coil is bad before I purchase one. No spark, kill switch checks out, coil gap is correct.
I have:
12.6K ohms from plug boot to black ground lead on coil mount bolt.
2.47M ohms from plug boot to red spade terminal on coil.
No continuity from red spade terminal of coil to black ground lead on coil mount bolt.
Looks like an open primary winding, it should be less than 10 ohms.. Pull the wire off the spade lug (kill switch) if it doesn't produce a spark, the magneto(coil) is bad.
