Yo guys, I'm looking at changing the oil in the rear end again, I want to do it up right. The car has a Borg-Warner 9-bolt diff with positraction. The factory calls for a 80W-90 GL5 oil with GM posi additive.
I want to go with synthetic gear oil this time. I was noticing that the Royal Purple oil claims that you do NOT need to use posi additives with their gear oil. What about M1 and Redline?
I don't want to add posi additive if not needed, or add too much, because then it gets too slippery and I lose the posi action altogether.
Any insight is appreciated, thanks.
