I had a Eaton posi trac installed on my 2009 Ranger 3.55 gears 28 spline 8.8 diff. 80w-90.
Eaton recommends mineral oil so I tried 80w-90 Motorcraft and added friction modifier. It lasted 5k before chatter started. Then tried Valvoline 80w-90 with and added friction mofidier and it lasted 5k and started to chatter.
So called Eaton techs, one said to try 75w-140 syn and don't add any FM . Another said 75w-140 would be not good for Pa winters try 80w-90 syn with FM . Both tech recommend Mobil 1.
So question is , can I use 75w-140 in Pa in the winter ?
Also, can you mix say 80w-90 and 75w-140 Mobil 1 ?
and what exactly is chatter and how bad is it for the diff ?
And if anybody uses a Eaton posi please give a recommendation for rear diff gear oil.
Thanks.
Thanks.
