SupremePossum
Thread starter
With how cheap you can pick up good 0&5w synthetic oils these days, the only justification IMO for a 15w oil is if 1: it’s completely free, and 2: it’s going in something like a 1940s Farmall.
If this is the case, then you can't win around here! Everyone is an expert and tells you one thing, then tells you the exact opposite. For better or worse, I'm running 15W-40 for a while, because I have a lot of it now
Just doing some head math, if you leave the 50w heat pad plugged in 24/7, and your electric is just $0.10/kWh, you’re talking ~$4/mo
Zero reason to leave it plugged in all the time, so no problem there
Think about it- the very best ICEs are about 38% efficient, and generator engines are probably in the 25-30% range, meaning for every 5HP of output the engine is wasting about 12HP of heat, or ~9kW for about 3.7kW of output. 50W is likely going to be inconsequential especially if there is any moving air near the cylinder block.
I don't think you can use those stats on a block heater. I for sure will do some tests, I do have a FLIR
Now it needs to get cold...
