People have been asking for examples of M1 not working in apps where it meets spec. I stumbled on this and thought I'd share...
http://www.lnengineering.com/oil.html#m96
Shown below are two examples of non-catastrophic wear, discovered in two M96 engines at time of disassembly, caused by long drain intervals and use of motor oils not necessarily formulated with the best wear performance in mind. Like mentioned earlier, the factory recommended drain intervals may be too long and recommended "approved" oils may be best for your engine:
cam sprocket wear, 2.5 Boxster M96 engine, using Mobil 1 0w40 at factory recommended drain intervals, ~35,000 mi.
cam chain tensioner pad, 2.5 Boxster M96 engine, using Mobil 1 0w40 at factory recommended drain intervals, ~75,000 mi.
